| diyAudio Sponsor | ||
I am getting hardly any gain from my linestage.
B+ is 250V V at pin 9 anode = 140 V before anode resistor = 230 V across cathode resistor = 10V cathode resisor = 470 current at cathode = 10/470 = 21 mA i'm using a 100K stepped attenuator the sound is incredibly bassy and very low in volume The guy who helped me build my psu says i should just use 2 ecc83 valves instead but i would really like to get this 12b4 working, i have little knowledge of tube electronics which is why I am calling on anyone who can help! I have a feeling that the 12b4 does not behave like a typical preamp valve and have attached the circuit as i have built it thanks in advance stuart |
#2 |
Should work like a charm as drawn. Expected gain should be approx 5.
What are you driving and what is driving the amp? Bassy sound indicates a hf roll off somewhere. That 220R grid stopper is really 220R and not 220k or something? /Olof
I'm not allowed to do magic, union rules... |
#3 |
i feel like a fool, 3 days i've spent on this, I just discovered that it does work like a dream like you say.... i had taken my output caps from the wrong side of the anode resistor, classic schoolboy error?
I have volume now... but.... an even higher volume of continual hiss/hum... quite high in pitch.... and when i turn my psu off i get cristal clear music for a second or two before the line stage runs out of juice... thanks for your reply, any ideas on the noise? cheers stuart |
#4 |
Sounds like you are using a poor supply. I recommend CRC and then regulation. Use a decent regulator, such as a TL783, for each channel. (Mouser part number 595-TL783CKCSE3, they deliver to the UK). Don't believe any of this audiophool folklore nonsense about unregulated supplies being 'more free, to let the music flow', because that is just misguided, sentiment-filled clap-trap perpetuated by the hard-of-thinking and the self-styled gurus. Ignore them and regulate.
Check you ground wiring too. |
#5 |
Stu,
Look at the 12B4 data sheet. Your anode load resistor may be too small. The NET load impedance the triode is working into should be >= 3X RP. The net load is the parallel combination of the anode load resistor, the 470 KOhm part, and the I/P impedance of the down stream power amp. The schematic implies DC heater power. If that supply is floating, try grounding it. The 12B4 is a very nice tube. However, it has an unpleasant propensity to be microphonic. Place silicone rubber "O" rings on the envelope over the micas to hold microphonics down.
Eli D. |
#6 |
thanks eli, I'm actually posting my headaches in another thread called '12b4 linestage' started by coffeedj
i feel a little guitly posting in 2 threads, however it was your initial schematic that inspired me to make this, i would appreciate any help you can give me. The heaters are indeed DC, I have not referenced them to ground inside the linestage yet as i do not know how. However this noise that i am hearing is more than just a little background hum, could you share also how you would route your signal around this linestage, I have avoided the same side as the heater supply. I have put together the two grounds of my 100K stepped attenuator and all input and output grounds connect to this and to the chassis. cheers stuart |
#7 |
ok, things are getting better, i have extended the umbilical cord to remove the psu a couple of meters from the linestage. this helped a little. The sound was very nice but still with some interference.
I then grounded the LT- directly to ground. The interference still exists but now it does not increase in volume as i increase the gain, this is better as i can at least turn the volume up to reduce make the problem reduce to the background. so now i have sound, the interference is like an untuned radio between stations. I don't believe the sound is great either, the vocals do not seem sharp and clear but mushy..... can anyone post a schematic similar to mine that they now works for sure? would be much appreciated stuart |
#8 |
Stuart
Could you please give the specs of your power transformer? Mike |
| 12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) | DougL | Tubes / Valves | 3 | 2nd August 2004 06:06 PM |
| Page generated in 0.09717 seconds (78.06% PHP - 21.94% MySQL) with 11 queries |
