| diyAudio Sponsor | ||
I got my hands on a new pair of 7695s...look like a power pentode. Any potential in a Class A amp ? Or any other ideas ??
#2 |
Interesting tube, at least according to the datasheet. You could use that very high heater voltage and rather low anode voltage to your advantage (= no heater transformer/winding required if you hook up heaters in series and add a power resistor or CCS to the chain to drop those extra ~5W).
They also have rather low Zout (1100R). This can be a plus (OTL would be an option if you had more of these) and a downside if you already own output transformers that you want to use with these tubes and they don't allow for suitably (low) transformation ratios. |
#3 |
Triode connected, you should be able to get 5-7W in push-pull. This would be a good candidate for AB2 or screen-drive, where you could get closer to 10W. The attractive feature is the low load impedance requirement, making the output transformer a much easier proposition.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
Ok...thanks SY...how would I achieve the 50V filaments?
#5 |
A transformer might work.
I'd probably series them, add series resistors, and use an isolation transformer.
| OT for audio but still tube | Andrewbee | Tubes / Valves | 1 | 12th August 2008 04:29 PM |
| A new audio tube | HollowState | Tubes / Valves | 50 | 23rd December 2006 05:41 PM |
| Octal tubes for 7695-style matrix amp? | bst | Tubes / Valves | 3 | 15th November 2006 08:52 AM |
| Tube audio transformer | audioPT | Tubes / Valves | 19 | 21st March 2005 01:09 PM |
| Page generated in 0.07780 seconds (72.88% PHP - 27.12% MySQL) with 10 queries |
