diyAudio Sponsor
Old 12th May 2009, 12:00 PM   #1
Default Resistor after volume pot
Hi, this is my first post here. I'm studying electronics and I want to ask what's what's the purpose of the series resistor after the volume pot, what are the effects of changing its value, what are the recommended values, etc.
I've seen this configuration in many places but I'm not sure how it works. Thank you.
Old 12th May 2009, 12:13 PM   #2
SY's Avatar
That diagram looks wrong.
Generally, a resistor connected in series with the grid is put there for RF suppression or to prevent oscillation. It's known as a "grid-stopper."
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th May 2009, 01:36 PM   #3
1 kohm.
Old 12th May 2009, 01:52 PM   #4
diyAudio Moderator Emeritus
ray_moth's Avatar
Gottlieb,
As SY said, that diagram is wrong. There HAS to be a path to ground from the grid. That o.1uF capacitor is preventing there from being such a path. The tube will be unbiased and will take excessive plate current,
Old 12th May 2009, 03:01 PM   #5
Sorry, my mistake. Here's the complete circuit. It's a cathode follower configuration. I more or less understand everything except the resistor in red.
Old 12th May 2009, 03:25 PM   #6
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
You can assume a loop between cathode and the ground of the pot. If it's resistance is low it's inductance may cause oscillations. I saw such a problem in Ampeg bass guitar tube amps, it caused HF oscillations.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 13th May 2009, 08:51 AM   #7
Thanks Wavebourn.
Is there a remedy for that problem you describe? Thank you.
Resistor on Signal Path before Volume Pot? kptseng Solid State 13 9th August 2008 06:40 PM
Shunted volume: pot & resistor values Sanaka Everything Else 20 13th February 2008 02:07 AM
What resistor and potentiometer values for GC shunt volume control? sharpi31 Chip Amps 2 20th September 2007 07:23 AM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Lowering a sub's volume by adding a resistor to the cable... robinmiller Subwoofers 3 7th January 2006 07:15 PM
Page generated in 0.07749 seconds (76.66% PHP - 23.34% MySQL) with 10 queries
