diyAudio Sponsor
Old 12th May 2009, 01:59 AM   #1
Question 6021 Amp project..looking for some input
Working on a "powerman" type build using 6021 subminature tubes. I have built a few prototypes with both a single push pull output and one with a parallel push pull setup. I can't decide one over the other so I would like to be able to "switch" the parallel 6021 in and out of the circuit.
I am thinking to keep the heaters hard-wired and the cathode and bias resistors will be a separate setup.
So that leaves 6 connections that need to be simultaneously switched off and on. That is where I am running into an issue...relays? latch circuits? 6 pole switch of some type?
Thoughts, suggestions, comments from the peanut gallery?
Thanks!
Tim
Old 12th May 2009, 04:27 PM   #2
Why not just find sockets for them and simply remove the paralleled ones when not needed? Sockets for those sometimes come up on Fleabay and I've used the old TO5 style op amp sockets with those also...
Dave
Very near future project, need input... chops Multi-Way 36 16th August 2007 12:20 AM
Help! Need input for my next project Shpoop Multi-Way 9 18th June 2007 02:56 PM
New amp project-some ideas of my own and looking for input from others... mr mojo Tubes / Valves 8 25th September 2005 04:19 PM
new project, need input please drfrink24 Multi-Way 10 27th October 2004 02:40 PM
6021 opinions Glass_painter Tubes / Valves 1 28th May 2003 09:51 PM
Page generated in 0.05764 seconds (70.08% PHP - 29.92% MySQL) with 10 queries
