diyAudio Sponsor
Old 11th May 2009, 08:28 PM   #1
Default OPT question
Greetings one and all!
I am building a small PP power amp based on the PP circuit of Nobu Shishido.
My question is, is an OPT sans UL windings better for a triode output stage? IOW lets say I have too OPT's the only difference being one has UL windings, would the one without the UL windings have any advantage over the one without?
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 11th May 2009, 08:30 PM   #2
No (provided that it is a competently made opt)
/Olof
I'm not allowed to do magic, union rules...
Old 11th May 2009, 10:27 PM   #3
Andrew,
It depends on how the UL connection is made.
Mostly it is merely a tap on the primary winding (two taps for the PP OPT).
In that case you can use the OPT for triodes without loss of quality.
A more sophisticated OPT will have separate UL windings (like McIntosh for instance).
Not using these will have a negative effect (coupling; leakage inductance).
Pieter
Old 11th May 2009, 11:35 PM   #4
Hi all,
the OPT's I have are original Dynaco Z565's so I should be okay then.
I did not know the UL taps were really simply taps. I thought they were derived from another separate winding, something akin to a cathode feedback winding.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.07521 seconds (70.11% PHP - 29.89% MySQL) with 10 queries
