| diyAudio Sponsor | ||
I found this article on the web : http://www.radiomuseum.org/forum/the...te_triode.html Could it be so simple ? I would like to have your feedback Regards Zig |
#2 | |
but that's what I expected to see. What if O.H. Schade had MOSFETs? I call it the Schadeode in honor of O.H. Schade who was the first I'm aware of to publish a description of turning a pentode or tetrode into a triode characteristic by the use of plate-grid feedback. http://www.pmillett.com/tubedata/beam_power_tubes.pdf Cheers, Michael |
#3 |
Yes, it is so simple. FETs are very similar to tubes. However, parallel feedback by voltage results in input resistance that depends on an amplification factor that depends on load resistance. It is not so simple. Also, MOSFETs have higher non-linear capacitances than tubes.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 |
Earlier today I finished curve-tracing sims to show the similarity between MOSFETs and pentodes with reference to Schade. I used IRFP240 and EL84 to show and verify.
Will publish them later today when I am at the right computer. The main problem, as I see it, is the input series resistor of the shunt feedback in combination with the input-capacitanace of the device. As Wavebourn says MOSFETs have bigger problems as they have non-linear capacitances (with the already high steady). Nelson Pass used this concept in his Zens but had to go down to ca 1kohm resistors to get good enough bandwith. Wonder if he had read Schade before........... About pentodes its not that bad but my Schade-sims of a upcoming 6AQ5 SE with gyrator-loaded 6C45 tells me the seriesresistor should not be bigger than 15k.
Brgds Lars |
#5 |
EL84,
Dont mind the figures, this is just to show what Schade already showed in 1938!
Brgds Lars |
#6 |
IRF
Brgds Lars |
#7 |
I think the capacitance issue can be mitigated by using a FET for the
input with the source on the input resistor or equivalent because the Ciss will be bootstrapped by the varying voltage drop across the resistor, and the feedback resistor can be made small enough to drive the gate of the output MOSFET. IF you don't want 1/Gfs for your Rp equivalent, there will also be a source resistor to bootstrap the Ciss of the output FET. I sort of like the idea of a MOSFET input and a pentode output. Michael |
#8 |
Gary Pimm built a Mosfet version of his Tabor amp using these cascaded Mosfets as the building blocks. Needless to say his virtual triode is a bit more complex than the ones proposed here.
Shoog |
#9 |
Hi Shoog,
Pimm didnīt make virtual triodes. He made virtual pentodes! He then "Schaded" the output "pentodes" to be fed by another pair of input "pentodes". As this guy knows what he is doing, he didnīt use triodes as input elements.
Brgds Lars |
#10 |
Thank for correcting me on that one.
Effectively he is attempting the same thing but in a two stage implementation Shoog |
| Page generated in 0.09762 seconds (85.68% PHP - 14.32% MySQL) with 10 queries |
