OPT grounding question
Old 13th May 2009, 09:23 AM   #11
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
I reckon Olof is 100% correct.
To drive speakers from an ungrounded source in which there is any possibility at all of B+ or the mains coming into contact with the speaker leads would be foolhardy and potentially dangerous.
The fact that the seondary of the OPT is insulated under normal conditions means nothing if the amp should ever be subjected to severe accidental physical damage due to impact or fire.
Old 15th May 2009, 01:06 AM   #12
Johan Potgieter is offline Johan Potgieter  South Africa
OK, the inportant stuff has been said.
Just a further small point: Grounding the secondary gives a certain reference to the interwinding primary-secondary capacitance. Ungrounded the secondary floats somewhere between B+ and earth; even that can 'bite' you when touching loudspeaker wires.
Bottom line: While there is no technical 'demand' to ground the secondary in your case, there is nothing against it and every reason from several points of view to do it. (Direct, no resistor.)
Old 15th May 2009, 01:29 AM   #13
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
When 50W was a huge power amps had floating 100V output and a separate feedback winding.
Why?
Because they used to drive symmetrical lines through the whole building so grounding could cause undesired feedback on input lines.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 16th May 2009, 01:32 AM   #14
OK Wavebourn, admittedly a good reason!
I was thinking more of the domestic case, or at most a stage situation with relatively short cables. Yes, don't remind me. Running sound through a building can be a real nightmare!
Old 16th May 2009, 02:44 PM   #15
Nihilist is offline Nihilist  United States
Thanks again guys. I can see the safety point of it clearly now.
I was concerned that the back EMF of the speaker might somehow influence the smaller driver tubes by modulating the ground, forming a sort of undesired feedback circuit.
My thinking was that if I had the OPT floating (with regard to ground) , the OPT itself would act as a buffer/isolator between the driver and the rest of the circuit.
IIRC, sometimes industrial/commercial AC power transformers are case grounded, but windings are not .
..................................Blake
Keep it simple
My Page Of SV1000 and DIY Stereo Links
Old 17th May 2009, 12:20 AM   #16
Do recognise that grounding one side of a winding will not cause signals to be necessarily set up in the 'ground'. That will only happen when part of that output circuit is common to the rest of an amplifier. Thus it is important to ground at one point only so that no part of the OPT-loudspeaker circuit (carrying relatively high signal current) is common to the rest of the amplifier to any appreciable degree.
Old 2nd June 2009, 02:06 AM   #17
rman is offline rman  Canada
rman's Avatar
The first amp I built from a diagram I found on the net did not show the secondaries of the opt's grounded So that was how I built it.
Then I built a slightly more powerful amp. I wanted to use the smaller one to drive rear speakers only in a Hafler matrix. Of course it didn't work because there was no complete circuit. I was confused at first, but I remembered seeing diagrams with one side of the secondaries grounded, made the change, and it worked. I realize now I could just have connected the black terminals on my amp together with the same result. After reading this thread and the safety aspect. I sure am glad I grounded those suckers!
Rolf.
OPT grounding questionHide this!Advertise here!
chassis grounding question mnr102 Solid State 2 12th July 2008 09:14 AM
Grounding problem question? excetara2 Solid State 5 10th November 2006 04:39 PM
Power grounding question falcott Chip Amps 0 21st September 2004 07:50 PM
grounding question skyraider Chip Amps 1 9th March 2004 09:12 AM
LM3886TF Grounding Question mothman Chip Amps 1 4th May 2003 11:42 AM
