Beginners attempt at SE 6EM7
Hi Rolf,
You said before you where getting bigger chokes, did you end up using them or was the bigger cap enough?
I've not bothered with a bigger choke yet (they ended up being out of stock) but will be trying a larger choke/smaller cap later to see what difference it makes. At the moment I'm just enjoying the amp as it is.
I'll also maybe try some of the other 6EM7 circuits that are floating around (thanks for your circuit btw).
Here's a picture of the finished amp..
www.erpland.com/amp.jpg
Chris
