Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5
Old 9th May 2009, 03:59 PM   #1
quality sound is offline quality sound  United States
Default Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-58
I want to see if I can find someone to rebuild my (2) 1930's to 1936 Hammond / Western Electric mono block amps using the Thorsten Loesch design using the UTC LS-58 transformer , In which I have (2) . One for each Hammond amp I want modified and built. Each Mono block amp currently has (4) 2A3, (2) 56, (1) 5U4G. Want point to point contacts if possible with excellent wire mapping inside. I will only use the best parts in this build with no exceptions. Only talented need apply. Your work will be published with an extensive photo layout of all your inside wiring work.
If you have any knowledge on the design and build, using Thorsten Loesch's concepts in building a Western Electric 300B/2A3 Hammond monoblock amp incorporating the UTC LS-58 transformer and your work and talent is first rate I look forward in speaking with you.
additional contact information: creativedeckworks@yahoo.com
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5Hide this!Advertise here!
WTB: Western Electric 300B (matched pair) + Hashimoto SE Output tr.'s cartman Swap Meet 3 22nd May 2006 04:47 AM
Western Electric 374A john Tubes / Valves 4 21st December 2005 03:17 PM
Western Electric 300B serengetiplains Tubes / Valves 4 16th December 2004 06:16 PM
Western electric VT1 tubes battradio Tubes / Valves 7 19th January 2004 03:29 AM
Western Electric PassFan Tubes / Valves 0 26th April 2003 01:09 PM
