diyAudio Sponsor
Old 8th May 2009, 10:21 PM   #1
jetbat is offline jetbat  United States
Default Circuit help
Hi, I was wondering if the components marked with red on the schematic are necessary or am I being redundant? I do not know if the tone stack would provide the necessary DC coupling and ground reference to make the red components unneeded. Any help would be appreciated.
Scott
Old 9th May 2009, 01:32 AM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
Your observation seems valid to me, I think you could remove the red-marked parts, at least in theory. In practice, though, if the treble pot has a poor track it will cause unpleasant noise.
Old 9th May 2009, 01:39 AM   #3
Yes, I would agree with Ray.
The second triode is properly biased; I have never experienced 'contol noise' under such circumstances.
Old 9th May 2009, 06:38 AM   #4
billr is offline billr  New Zealand
the 12ax7 needs a grid resistance of about 1 meg, have a look at the specs and you will see this. I would leave it in.
Old 9th May 2009, 07:31 AM   #5
Of course !!
Old 9th May 2009, 11:19 AM   #6
Kindly, which specs are you referring to? Unless 'grid leak' bias is used, where minute grid current gives the necessary grid bias with a grid resistance of some 10meg - 20meg (which can be advantageous when fed from a low impedance source), the G1 resistor to common may be anything. It does not play a role with sufficient cathode bias as no grid current would exist.
Old 9th May 2009, 08:01 PM   #7
jerluwoo's Avatar
He is talking about the maximum grid resistance when the tube is self biased (has a cathode resistor) or when it is fixed bias (negative supply on the grid). 1meg for self bias and 500k for fixed bias, based on most datasheets.
Old 9th May 2009, 08:19 PM   #8
The grid of the second stage already has a Rgk of 250K + 250K + 2.7K at maximum, through the treble stack, if the 0.44µF capacitor is removed.
P
Old 9th May 2009, 09:13 PM   #9
No it doesn't, if the knobs are turned all the way round the pot is shorted out, turning the grid resistor into a 2.7k on its own.
It's a dc thing for the grid, you need the 1M resistor in there, the cap blocks the parallel action of the tone controls maintaining the grid resistor to it's original value.
hope this helps.
kind regards
bill
Old 9th May 2009, 09:36 PM   #10
R.I.P.
Bill,
Sorry but you are wrong. With a 2k2 R in the cathode circuit, the grid resistance to ground can be pretty much anything, as long as it has some resistance. One meg would be an optimum MAXIMUM value, but it can be taken dowm to zero ohms with NO problems at all.
Regards, Allen (Vacuum State)
6c4 pre-amp circuit dito Tubes / Valves 2 2nd January 2007 07:42 PM
555 circuit 24v down to 14v magudaman Parts 7 1st May 2006 12:29 PM
amp circuit help scott3292 Solid State 10 11th July 2005 11:16 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
What circuit? palesha Solid State 1 24th November 2002 10:18 PM
Page generated in 0.09677 seconds (80.54% PHP - 19.46% MySQL) with 11 queries
