Has anyone had the chance to test this kind of amp? A JJ 2A3-40W push pull biased in Class A. Is it possible to get 30/40 watts on a 4 ohm speaker? |
#2 |
NE-VER .
#3 |
Maybe for 2-3 minutes
Cheers! |
#4 |
Even though JJ-2A3 are 300B with 2,5V heaters, it is not doable.
#5 |
May be we can use 4 pairs of 2A3's to get 40Watts output. The output transformer should be rated for 250mA idle current.
Also, we need a 2 x 2.5V 10A for the 2A3's filament supply. The price of 2A3 is not cheap at all. I would rather just use 2A3 in singled end amplifier that gives me 3.5W sweet and beautiful sound... Johnny |
#6 |
The 2A3-40 by JJ is a very good tube.It is very stable and not so difficult to select; I have Sofia.
At this link: http://www.multitask.it/diy/fabfour.JPG you can see the first prototype of a pair of amps using these tubes. This is a second version (for my friend): http://www.multitask.it/diy/1000eniumab.jpg The rms power is 45 w - 8 ohm and 60 w at 4 ohms; impulsive around 75 w. It works for the 40% in class A. Bye Walter |
#7 |
Once again:
JJ 2A3-40W has nothing to do with a 2A3. JJ 2A3-40W IS A 300B WITH 2,5V HEATERS! The "funny" guys att JJ are still trying to fool us by having the RCA Ua/Ia-curves in their data sheet. |
#8 |
Correct, the 2A3-40 is a 300B with a 2,5 v filaments.
The good thing is that it can be powerd with ac on fil. and the hum is very low. In my last amp the noise at the otuput was abou 0,45 mv without Feedback. Same project with 300B are 0,7-0,8 mv. I am able to send, ASAP, the curves of this tube from my Sofia . Bye Walter |
#9 |
Banned
That is a good information: all those who wish to build the RH300B amplifier can do it with the JJ2A3 tubes obtaining the same power as with a "normal" 300B, but with less hum due to AC heating!
I did not know that -- I do not follow new tubes
#10 | |
distortion and damping factor. Check out the SE op point at 450V anode and 80 mA into 2000 ohms. Class A (more or less) push-pull at this op point and 4000 ohms plate-plate would give you about 35W at the anodes and well over 30W out after losses. The anode dissipation will be 36 watts at idle. The chart is for a 300B but the JJ 2A3-40 has the same characteristics. For a 4 ohm speaker you just need a 4000 ohm to 4 ohm OPT. Michael |
| 2A3s in push pull; class A | Sir Trefor | Tubes / Valves | 39 | 30th January 2011 10:03 PM |
| Class A push-pull | Nikolas Ojala | Pass Labs | 5 | 24th August 2009 12:58 PM |
| Class A, push pull amp using transistor | space2000 | Solid State | 18 | 7th August 2008 02:53 PM |
| Class A Push Pull with 6L6GC | d1camero | Tubes / Valves | 9 | 4th December 2007 08:35 PM |
| EL34 Push Pull in Class A | arnoldc | Tubes / Valves | 29 | 17th May 2006 11:52 AM |
