#11 |
And
Alex if I can say, The syntax and other errors could be corrected, BUT The bad attitude, and basic psyhology of personality I am afraid, could not be corrected, in same way * Yes, Belgrade, in Serbia is the place I am living just like anybody else living somewhere, I do not see what is to do with, about the topic on this public forum... * I am afraid that You is the one who is giving a lecture * cheers
#12 |
As we dutchies say 'Zachte heelmeesters maken stinkende wonden' so:
Really sorry but this whole article or whatever one calls it is crap. The assumptions you make, the way you hand it out as the gospel and lace them with either wrong or pointless topology's. Establishing your own standards for levels and the 'electromagnetic garbage from the ether' joke.... 'All of the heat transformer units should be placed under the chasses' ? Yeah sure ![]() 'overloading input of the amplifier, supplying amplifier input with a opposite phase, coloring the signal with a cables reactive load and shorting the bandwidth from the booth sides via wrong potentiometer' Say what? We should leave the tube filaments to “rest”, go read tubecad and the likes and I guess you should go back to drawing, painting and media
http://tda1541a.com The Final List |
#13 | ||
Banned
This is basically what I smelled from the first few lines, but did not want to be the first to point out. Quote:
#14 |
Guys, there's helpful criticism and there's unnecessarily personal sniping and snark. I think this has crossed into the latter. Please keep criticisms to the technical details.
If there's a sucker born every minute, where do the rest of them come from? |
#15 |
I haven't had the time to fully read through it just yet, but I will. I did glace through it though and it seemed like it would be worth my read, although it is a tad long. The one thing I saw I was wondering about was picture 21 (I think) where you show a 6SN7 coupled to a 801. Is the elaborate hum cancellation on the 6SN7 heater really necessary? I mean I have never had a problem with AC heater hum on indirectly heated tubes with just a small value cap across them (sometimes) and a very small dropping resistor. Like I said though, I will give it a deeper read, thanks for posting.
Cheers James |
#17 |
diyAudio Chief Moderator
Saved the article. Thanx.
| Wikipedia Article on "Tube Sound" | sardonx | Everything Else | 3 | 9th February 2013 02:23 PM |
| Looking for Old Elector Tube Preamplifier article | stevesebastianb | Elektor | 25 | 28th August 2009 09:39 AM |
