#21 | |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#22 | |
mostly thinkerer
The first time I saw something like that was from Broskie...and I liked the idea (simple, good for me )... later on I found Jackinnj's work with the LR8N3 A very interesting feature of the LR8N3 is that it is said to be happy with a meager 0,5mA being drawn through it. I got some LR8N3 and some 400k/2W potentiometers with the intention of building regulated supplies for experiments. I would use a upper resistor of about 1k2 (to set current to 1mA) and the 400k to set the voltage, with maybe a smaller potentiometer in series to allow 'fine adjustments'...but I haven't got that far, yet... Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
#23 | |
#24 | |
Edit: with 10 Ohm resistor and 12V Zener it will be something about 900 MA.
#25 | ||
Michael, Wavebourn, could I ask you to post sketches of what you're talking about? A beginner at solid state circuitry, I'm trying to learn from you and am not sure if what I imagine from reading your words is even remotely similar to what you're talking about. Also Michael, talking about Gyrators on filaments, did you see Rod Coleman's post? If you haven't already you might find it interesting. I built it in simple form (ie. much simpler rectifier and filter front end) and it works well/sounds good. Also tried a version with the top half of his circuit mirrored in the bottom, the whole thing fed by a current source. Thanks |
#26 |
Hearinspace;
I was talking about Revintage's power supply. As drawn, it is powered from a voltage source with I assume some ripples that he tries to remove like a choke does. Unfortunately, a gyrator is not a choke, and it does not accumulate an energy, so I suggested him to turn it into a source follower that would be more effective in this particular application.
#27 | |
Thanks, I'll look at that. BTW. I'm just about to sit down to try a couple of MJE5731A's in your High AC Impedance Load ('gyrator') circuit (The one you posted on the Anti-triode thread). Will post if I get it to do any tricks. Thanks again for your help |
#28 | |
#29 |
I was just going to try something/anything with a bench power supply. Dig up a tube that fits an already wired socket lying around the bench and start with that. However, If you are willing to lead me through the design process with something (which would be really awesome) then I'll choose something specific. How about a 417A. - Vpk = 150VDC /Ip = 18mA (Vg=-1.5VDC) I'll have up to ~500+VDC available for B+ (the output tube is a 10Y)
Thanks |
#30 | |
Do you have also a 350V source? In such case gyrator will have to dissipate less than 4W.
