| diyAudio Sponsor | ||
#111 | |
No, you can;t. But you can use NPN transistor instead of N-type MOSFET, Base-emitter breakdown voltage is about 5 times less than gate-source bias for given current, so adjustment will be needed. Also, BJT have a secondary breakdown due to uneven base width.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#112 | |
Sheldon |
#113 |
Thanks Sheldon. My question is a very simple one and isn't really about the amplifier circuit per se. It's two pronged, first it's that I've never seen current from one supply run through the rectifier of another and wanted to make sure that that was really what was happening before I filed it away in my mind as a workable option. And then I also wondered (if that is the case) doesn't the less filtered 60V supply add noise to the previously filtered 210V current? None of this is meant to be critical or judgmental in any way. I'm just trying to learn.
#114 | |
#115 | |
Hadn't thought about the second part of the question. Interesting. I guess that it would add a little ripple, but not the full ripple amount of the 60V supply. Since they are in series, the two supplies form a divider, so t would depend on the output impedance of the 210V supply, as to how much the ripple in the 60V supply would modulate the voltage on the 210V node. Shouldn't be hard to design for low ripple there. A low impedance supply at 120Hz would have current ripple at that node, but not voltage ripple. Curious as to Michael's take. Sheldon |
#116 | |
There are some shortcuts in this circuit because it's on a breadboard. For example, I would prefer the bias referenced to the power tube cathode rather than ground, but this is convenient for testing. Cheers, Michael PS I worry about a short from the top of the 1100V supply to ground so I add a big reverse biased diode across the 210V supply. |
#117 |
Michael, Thanks for taking the time to post so much detail. It's really appreciated. I'm digesting it now. Maybe post again once I understand more, thanks!!!
#118 | |
#119 | |
#120 | |
I wonder if something like this would work? |
| Page generated in 0.12916 seconds (82.56% PHP - 17.44% MySQL) with 11 queries |
