diyAudio Sponsor
Old 7th May 2009, 04:31 PM   #1
newtube is offline newtube  United Kingdom
Default spare transformer wires?
Guys, i'm about to start wiring up my simple se and notice i'll have a whole bunch of spare wires from my transformers, mainly from the mains trans, what do i do with them fella's?!!!
Darran.
Old 7th May 2009, 05:23 PM   #2
HollowState's Avatar
Cut off the bare ends (if any), tape up or put heat-shrink over each individual wire to cover the ends and just tuck the bundle out of the way. Don't cut the wires short because you may want them some day.
"The human race is just a chemical scum on a moderate-sized planet orbiting round a very average star in the outer suburb of one among a hundred billion galaxies." ~Stephen Hawking
Old 7th May 2009, 06:12 PM   #3
boywonder's Avatar
Or stick an extra terminal strip under the hood and solder them (or screw them) to it, so that they go nowhere.
Old 7th May 2009, 07:33 PM   #4
Thanks, i was reluctant to cut them short as i know i'll end up useing the trans for something else. . .
Cheers for the help, i'll be bothering you for more info on connecting it soon i'm sure
Tubelab sse transformer wires newtube Tubes / Valves 9 12th May 2009 02:29 PM
Twisting transformer wires? Dominick22 Chip Amps 29 1st June 2006 11:34 PM
Transformer wires too small? drfrink24 Chip Amps 3 4th March 2005 07:45 PM
wires of output transformer are too thin! zxx123 Tubes / Valves 5 4th February 2005 11:18 AM
Transformer Wiring... 5 wires on secondary? Parker_SMC Solid State 5 11th October 2004 04:10 AM
Page generated in 0.07660 seconds (64.27% PHP - 35.73% MySQL) with 10 queries
