schematic for Audio Research SP11? - diyAudio
Old 27th April 2003, 11:02 AM   #1
sean is offline sean  China
Send a message via ICQ to sean Send a message via AIM to sean Send a message via MSN to sean Send a message via Yahoo to sean
Default schematic for Audio Research SP11?
Can anybody help me with a schematic for Audio Research SP11?
Sean
gss
Old 27th April 2003, 06:16 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
In case no one here has it, check:
http://nanaimo.ark.com/~pat/tube.htm
Look at the bottom of the page to see "How It Works"
/Hugo
Old 28th April 2003, 10:40 AM   #3
sajti is offline sajti  Hungary
Check out this page!
Sajti
Old 28th April 2003, 11:09 AM   #4
Default Tanks all!
gss
Old 5th March 2005, 12:37 AM   #5
mirlo is online now mirlo  United States
Default Parts list?
Most of the parts of the SP-11 are called out, but the JFETs and MOSFETs are not.
Does anyone know what they are?
Old 6th March 2005, 03:56 PM   #6
It is the politic of ARC to match and color code their j- and mosfets. Nobody knows what it is.
Reinhard
Old 7th March 2005, 03:31 PM   #7
expert in tautology
bear's Avatar
I haven't looked at the ARC SP-11 schematic yet, but my answer to the question is: not terribly critical!
The FETs need to be low noise if they are in the front end of the phono stage...
Beyond that all you need to look at is the IDSS which you can figure out from the rest of the circutry around them - if it matters at all...
The Mosfets and the Fets need to be able to handle the voltage drop across them, so they can be selected on that basis, and on the basis of the power they are dissipating where they are in the circuit... the bias set up for the Mosfets will give the clues needed to determine which ones will work in the circut as shown, although you can always dork some values to match another mfrs devices... there are only a handful of mfrs that made small mosfets in the 80s and 90s...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 12th March 2005, 03:14 PM   #8
expert in tautology
bear's Avatar
Anyone got an ORCAD reader???
I can't open those nice files from the italian site...
Whaaaaa!
Tried getting something out of their site - no response through their "free download bot"... Grrrr...
would be nice to see that stuff in .pdf
anyone??
_-_-bear
PS. I'll post it on my site if someone can transfer it to .pdfs!
_-_-bear
Old 12th March 2005, 05:10 PM   #9
Whaaaaa!
anyone??
_-_-bear
I opened them with CorelDRAW photo editor.
sajti
Old 13th March 2005, 07:53 PM   #10
expert in tautology
bear's Avatar
Don't have that program.
_-_-bear
Schematic of Audio Research VT 100 Alex helge Tubes / Valves 8 1st September 2011 12:16 AM
Audio Research D125 Schematic? thermionic Tubes / Valves 1 16th May 2009 03:41 PM
audio research sp11 upgrade help please selcuksiyoni Tubes / Valves 4 4th November 2006 04:56 PM
schematic for audio research classic 120 amps? audiomatic Tubes / Valves 5 3rd May 2004 04:25 PM
I need the Schematic of Audio Research ph3 purer Tubes / Valves 12 20th February 2003 06:58 AM
Copyright ©1999-2017 diyAudio
