#11 | |
-e |
#12 | |
Eli is probably right. The can that looks like a capacitor can is a dropping resistor. The tube heaters eat 150ma of current, and a 200 ohm resistor will drop 30 volts at 150ma. 50 + 35 + 30 = 115V, which was what you would get from the wall. So the 200 means 200 ohms, and the 630 means... something else. Primitive little thing. Sort of the least turntable your money could buy.
-e |
#13 | |
| Question on Opamp upgrade on phono stage | marchewd | Analog Line Level | 31 | 18th December 2012 06:09 AM |
| NAD PP2 Phono Preamp Upgrade | Algar_emi | Analogue Source | 36 | 11th November 2011 06:37 PM |
| AN M2 line upgrade to phono | bartasas | Solid State | 0 | 10th June 2008 12:24 PM |
| Upgrade Project SE Phono Box | Aquarium | Analogue Source | 0 | 27th September 2005 09:17 PM |
| Phono stage upgrade | rmihai | Analogue Source | 5 | 17th July 2005 01:41 PM |
