ThermalTrak transistor application. - Page 2 - diyAudio
Old 6th May 2009, 06:01 PM   #11
Sheldon is offline Sheldon  United States
Originally posted by revintage
For a "normal" PP I would substitute the cathode resistor(above the diode) with a CCS as to make both tubes having CCSs at their cathodes.
Why is this with thermaltrak better than just a CCS under each cathode (not a rhetorical question)?
Sheldon
Old 6th May 2009, 06:39 PM   #12
tomchr is offline tomchr  Canada
tomchr's Avatar
In order for the two currents to track, the diode will need to match the Vbe junction of the NPN. This is easily done by using a matched pair of NPN's and wiring one as a diode by shorting the Vcb junction. This is what's done in a standard current mirror.
One could also use a Wilson current mirror.
Generally, if the transistors are from the same batch they will match closely enough for practical purposes. If you want tighter matching, buy 10x what you need and match them with a curve tracer. If you go through all the trouble of matching the transistors, keep in mind that they will need to be thermally coupled and the layout parasitics should ideally be identical for all the transistors.
One could also just make the circuit less dependent on Vbe matching by inserting a degeneration resistor in the emitters of the two NPN's. If the voltage drop across the resistor is significantly larger than the Vbe mismatch, the matching will depend more on the matching between the resistors (keep them close together, oriented the same way, away from heat sources, etc) than on the Vbe matching. For precision IC design, I generally go with 200-400 mV of drop across the resistors. If you don't care about the last mV of headroom (which you most likely don't for tube amps), you could drop a volt or two and achieve excellent matching...
~Tom
Old 6th May 2009, 07:30 PM   #13
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Tomchr,
Thanks for the suggestions. I'm aware of the typical current mirror (2 devices, 1 shorted base-collector). I was just thinking, if the internal diode of the thermaltrack transistor is a close match to the B-E junction of the BJT portion. It would be cool to have an all in 1 package mirror. Would eliminate a component and give maximum thermal coupling between each half of the mirror.
Your right. 1V drop across some degeneration resistors would be no problem for this application.
Old 6th May 2009, 07:48 PM   #14
Alephs with Blumlein's garter combine extremely
low dropout with excellent current matching.
Manufacturing variances of Beta and VGS-on
don't matter in this topology. Only VBE drops
and resistors need match, and those are a
gimme...
Old 6th May 2009, 11:27 PM   #15
tomchr's Avatar
Oh... It just dawned on me that the diode and the transistor are in the same package. Neat. At least then they'd be very close to the same junction temperature (unless you burn a whole bunch of power in one device and not in the other). While it is indicated as a diode on the schematic, I bet it's actually an NPN with the collector and base shorted. The two devices could potentially match very well.
What's the part number for that Thermaltrack device?
I'm curious to hear what you find out as far as functionality and performance goes.
Thanks,
~Tom
Old 6th May 2009, 11:52 PM   #16
Jeb-D.'s Avatar
There is actually quite a few. On Semi makes them, if you google "thermaltrak" it will turn up some stuff. They were designed for output stage of solid state amplifier + tracking diode for the bias. I figured since the biasing resistors in tube output stages dissipate a fair amount of power, these transistor may work as a mirror (assuming that the diode matches the B-E portion of the BJT).
Old 7th May 2009, 12:25 AM   #17
tomchr's Avatar
I'm looking at the NJL0281D from On Semi. I find it "interesting" that they make a bunch of claims about thermal tracking but don't specify any of it. All they show for the diode characteristics is the forward and reverse current vs voltage.
Anyway... Good luck with it. I'm curious to hear of your findings.
~Tom
Old 7th May 2009, 12:32 AM   #18
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
By the way, today I've asked in SS forum if anybody can name a good double NPN transistor, medium power, no need for Vcb more than 30 Volts, with separate emitters. Nobody answered.
Any suggestions?
The Devil is not so terrible as his math model is!
Old 7th May 2009, 12:35 AM   #19
Wavebourn's Avatar
You can add a trimmer, with a center to ground, connecting a diode and an emitter to it's ends. Such a way you can balance current reflected from the left tube to the right one.
Old 7th May 2009, 12:49 AM   #20
http://www.analog.com/en/other/match...cts/index.html
Though these are possibly too low power for direct use
in line with cathode currents, would work fine as VBE
voltage references and comparator/drivers for Alephs.
I doubt any pair of Blumlein'd Alephs really needs this
level of physical transistor matching to get darn close.
I been plannin to abuse old germaniums to achieve
an even lower dropout. Nothing needs match but VBE.
Matched current sources that work down to less than
a Volt on each drain. (You still need a 12 volts pull-up
from somewhere else for driving the gates)
Ye olde National LM194 also comes to mind....
On Semi ThermalTrak davidallancole Solid State 639 1st May 2013 03:29 AM
Practical use of ThermalTrak diodes ceharden Solid State 5 9th April 2009 07:00 PM
OnSemi ThermalTrak Arius Solid State 8 26th August 2005 05:09 PM
ThermalTrak circuit design Mambo Solid State 4 12th July 2005 12:03 PM
Copyright 1999-2017 diyAudio
