weird old amp:need help
Old 6th May 2009, 04:04 AM   #1
bullpeters is offline bullpeters  Australia
bullpeters's Avatar
Default weird old amp:need help
I have a Strauss 60. Old p/p amp. 2 x el34, 3 x 12ax7. Huge p/t and o/t, big enough to a power small town. I replaced the caps etc as it was very dangerous, the two big cans were isolated fom the chassis and they were conducting the full load thru their outsides..on purpose. There is plenty of voltage were it should be, the valves are fine, But no sound, well very little volume.Replaced volume pot. It also has a strange bias set up, with pin 8 running 2 parralel caps, a zener diode and a fuse all in parralel to earth. I have never seen this before. I need help. What could be the cause of the lack of volume
Old 6th May 2009, 07:20 AM   #2
costis_n is offline costis_n  Greece
Schematic?
weird old amp:need helpHide this!Advertise here!
Weird e_fortier Class D 3 4th July 2008 01:16 AM
Weird cat experiments poobah The Lounge 10 26th July 2006 11:53 PM
Here is a weird one mashaffer Solid State 2 26th March 2006 12:23 AM
weird karma Everything Else 1 26th May 2004 03:10 AM
weird karma Everything Else 8 6th May 2003 10:42 AM
