diyAudio Sponsor
Old 4th May 2009, 08:26 PM   #1
IDSKoT is offline IDSKoT  United States
Default Tube Amp / Pre-amp kit?
I'm kind of new to Tubes. Really interested, just kind of new. Does anyone know a website or a place I can buy a tube amp / pre-amp kit for a fair amount? Preferably something cheap. I just want to try to understand how they work with a hands-on approach.
Old 4th May 2009, 09:03 PM   #2
scope out tubelab.com, George is is in Ft. Lauderdale, almost local.
Old 15th May 2009, 07:53 PM   #3
Default S-5 kit
The S-5 kit k-16ls is the cheapest and easiest kit around. It comes with everything needed to assemble a working tube amp with a tone control/preamp option that is recommended. Tons of mods on this site and lots of levels in the learning curve from novice to expert. Spare and replacement parts are also cheap if by chance you drop a tube, or reverse pol a cap ;( . Mine is playing blue grass music through a set of old PhazeTech 10" towers. It sounded so good I built another as a gift for my brother.
Old 16th May 2009, 12:07 AM   #4
Default Re: S-5 kit
Thanks. Any link for this kit? I'm interested.
Old 16th May 2009, 01:02 AM   #5
tinitus is offline tinitus  Europe
I think I might build the new Decware monokit ZKIT2
Just have to figure out the speaker fore it
Old 16th May 2009, 04:35 AM   #6
ccschua is offline ccschua  Malaysia
for beginners, can I know which kit offers tube amp build up with the explaination of the parts / values selection. I read the AX84 or the aiken project with good detail explaintation but that was used for guitar amp.
tks
Old 16th May 2009, 05:56 PM   #7
If you haven't seen it already check out the bottlehead site http://www.bottlehead.com. They've got a lot of kits and a helpful group on the forum.
I got started in this hobby by repairing a Heathkit amp - the manual had an incredible amount of troubleshooting help as well as information about the amp itself. I wish they were still around.
Charlie
Old 16th May 2009, 08:09 PM   #8
Default s-5 K-16LS Push Pull tube amp kit
There are better kits than the K-16LS but we don't all have a couple grand to spend on a "starter kit" and more power to those who do. It seems to be the most flexible and most written about kit next to the Dynaclone ST-70. This kit can be up and running one evening if you have had any circuit board experience. It comes with US made GE tubes and is a push/pull design. I recommend some high efficiency speakers (4ohm 91db or better). Check out S-5 here- http://www.s5electronics.com/thome.html
I hope this helps,
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 05:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 04:09 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 02:19 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 07:47 AM
Page generated in 0.09317 seconds (75.86% PHP - 24.14% MySQL) with 11 queries
