Genelex gold lion el84 reissue - ARCING - Page 2 - diyAudio
Old 4th May 2009, 08:30 PM   #11
adamus is offline adamus  United Kingdom
bias is fine, its 36ma through a CSS, if it goes then it just runs away
Old 12th May 2009, 01:00 PM   #12
Send a message via MSN to MBMerlot
Default Gold Lion EL84's
I've had the same problem with these tubes. It seems that the cathode - grid - to plate alignment is off on 3 of 4 that I have. I guess I'll try the Mullard reissue's.
Old 12th May 2009, 02:03 PM   #13
Default Re: Gold Lion EL84's
What are you saying - you've had arcing or "bright glowing" tubes? I'd be interested to know.
Just FWIW, I've had about 100 pieces pass through here with just 1 dud. It sounds like there may be another problem beside the tube in play here.
A word of warning - the "factory match" is horrible! I've had "factory matched" quads with 11 ma difference in plate current. And a poorly matched quad almost invariably has one or more "current hogs". These tubes will often red plate, etc., but it's not the tubes - it's the poor matching.
With 3 of four acting up I'd guess either you have a poorly matched quad or you have tubes that were severely shocked in transit.
Old 12th May 2009, 05:57 PM   #14
mine flashed, and one had a horribly bright hotspot in the middle of the heater.
Just had a call from the supplier, they have tested it an confirmed its arcing when approachign 300v, so they are replacing it. Good service.
Old 12th May 2009, 07:21 PM   #15
Jim,
The ones that I have are in a Dr. Z Prescription Extra Strength Amp.
I'm experiencing the exact same physical symptoms as yours. From my experience. This occurs when the distance from cathode to plate is off alignment.
Probably going to call EH and tell them about it. Have you had 100 and only 1 out of that bunch did that to you? I would like to know, because I do plan on contacting them about it.
PS. Making tubes is an art form. They just haven't reached the pinnacle.
Old 12th May 2009, 10:43 PM   #16
Yes, just 1 failure out of about 100 tubes.
But I can't make out what happened to yours, since I didn't describe the physical symptoms (there were none, it just died - bad connection internally??). Are you saying the 3 tubes arced or that they had hot spots on the plate?
Old 13th May 2009, 12:49 AM   #17
Screen grid meltdown, etc.. JJ's work fine in the amp, Mullards work fine in the amp. It's not the amp.
Yes, the plates are glowing red from electron bombardment. Like I said before, typical of a misalignment inside the tube.
Old 13th May 2009, 03:16 AM   #18
It may well have been the tubes - but according to what I can find the bias on the amp is not adjustable. Is it cathode biased?
Were you able to confirm the bias was in the normal & typical 30 ma. area? Forgive me if I seem to be cross-examining you, I don't mean for it to sound that way. But just because a set of JJ or Mullard worked fine does not narrow it down to the Genalex tubes themselves when they were acting up. If the bias is not adjustable and is not cathode bias, a set of "hot" Genalex could act just the way you described and not be defective. They could have been just passing too much current and the screens and/or plates overheated. Sets of relatively cool JJs or Mullards wouldn't necessarily act up the same way.
I've seen that exact scenario many times on many different amps.
If you have any comments please share them, and thanks again!
Old 14th May 2009, 06:31 PM   #19
bleugh.....
got my replacement tubes..... and one is exhibiting the indredibly bright heater again. instead of the normal orange glow its really whitish yellow in the section you can see through the hole in the plate.
its not arced as yet.....
the quality control on these seems really bad. for instance, one of the tubes as about 2mm of heater filament exposed at the top. The other has barely anything, not great on tolerance control.
I hold out little hope for the replacement tube with the hotspot on the heater.
volatge measures a perfect 6.3v ac.
Old 14th May 2009, 07:31 PM   #20
OMG..... i really hope this is a mistake on behalf of the supplier.
whenever i send anything back component or toolwise i alway put a black spot on it with a sharpie marker. mainly because i have a bit of a trust issue.
Pulled the valve with the bright spot in it..... and there is my black spot. All this after i was promised they were replaced. grrrrr
I hope to god its a mistake, otherwise name and shame is coming.
SimplSE Gold Lion KT77 tube set nvrgdenuf Swap Meet 0 2nd August 2009 10:47 PM
Gold Lion KT88 (lightly used, matched pair) n_maher Swap Meet 1 26th May 2009 07:42 PM
Genelex Gold Lion KT88s (reissue version) (matched quad, lightly used) n_maher Swap Meet 8 10th September 2008 07:01 PM
Genalex Gold Lion KT77 Tam Shaun Tubes / Valves 24 22nd August 2008 03:05 AM
Gold Lion KT88 Reissues marshall1988 Tubes / Valves 1 29th November 2006 08:18 PM
Copyright 1999-2017 diyAudio
