diyAudio Sponsor
Old 4th May 2009, 10:10 PM   #11
The original feedback caps in my STA15 weren't silvered mica. If you look at the circuit diagram you will see pr after the caps' values. That stands for polyester, which the ones in mine were. So if you want the sound of the Sixties, look for some polyesters!
Old 4th May 2009, 10:42 PM   #12
Seriously though, LCR do a range of 160V axial 2.5% polystyrene caps from 10pF to 3.3nF. You can easily make 267 and 340 by parallelling a couple of caps and 1000pF is available as a value. Rapid sell them.
Old 5th May 2009, 08:23 AM   #13
I suspect that Radford used - within reason - what ever capacitor type he thought suitable at the time and probably made changes that did not appear on the circuit diagram; I know this is the case with the transistor amplifiers as I did 8 weeks temporary work for him in the mid '70's.
Don't forget that a lot of these old amps may have had unsympathetic repairs over the years so may not have the correct parts. I always look for signs of previous repair before attempting any work - it has saved a lot of time and frustration!
I have repaired/restored STA12's STA15's, all marks of the STA25 and various pre-amps, most of which had capacitors of different dielectric. In the NFB loop I have found both polyester and polystyrene.
Then there comes the question: do you restore back to 1960's spec or make use of modern components?
Old 5th May 2009, 04:45 PM   #14
bigwill is offline bigwill  United Kingdom
Oops maybe they have polyester / polystyrene
Old 7th May 2009, 11:41 AM   #15
pointy is offline pointy  United Kingdom
pointy's Avatar
try a few out at the shop with a meter and you should find something that sounds good in the end ................(they never put on schemos
the exact valves only the part number. so there is always some trial and error.)
hitachi capacitors? feedback please jarthel Parts 0 15th June 2007 12:05 AM
feedback on panasonic pureism and x-pro capacitors jarthel Parts 1 3rd May 2007 11:18 AM
how important are feedback capacitors to prevent oscillation in active crossover? mazurek Parts 8 22nd January 2006 07:19 PM
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 08:03 AM
Page generated in 0.07355 seconds (70.58% PHP - 29.42% MySQL) with 10 queries
