| diyAudio Sponsor | ||
I have a 40VCT (20 - 0 - 20) transformer that I'm using to make a 40v PSU with a FWB rectifier, what I need to know is, what do I do with the CT? Whats the difference between grounding it and leaving it unconnected? I tried to search but the search engine wasn't very helpful.
#2 |
Do not connect the CT to anything. Protect it form touching anything by folding it and either taping it up or slide a piece of heat shrink tubing over it. If you used the CT, you could get ± 20V.
"The human race is just a chemical scum on a moderate-sized planet orbiting round a very average star in the outer suburb of one among a hundred billion galaxies." ~Stephen Hawking |
#3 |
DO NOT ground it if you will have either end of the bridge connected to ground.
#4 | |
This is what I did, I just had a moment of confusion. New baby=no sleep=maybe I should check all my work, twice. |
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Are you a newbie at PS design?? As in, you won't get an exact 40VDC from this transformer.
Appx 56VDC for straight Cap. 36 VDC for choke input design OR 40 VDC straight cap plus regulation My apologies for noting this if your already aware. _________________________________________________R ick.... |
#6 |
This will be my 6th one. Although it is the first solid state FWB PSU I've made, hence the moment of confusion. I have a few RC filters to bring the voltage down and I'm not concerned with 10% (+/- 4v) error, which I've found isn't noticeable, at least to me. I got it sim'd out with PSUD II as well. Thanks for checking though
It is a psudo-dual mono supply with 2 small chokes in some LC filters at the split, followed by a few RC filters and a gyrator at the end (as an experiment) to kill what ever ripple is left. |
| Quick question on the PP-C1 amp | athos56 | Tubes / Valves | 13 | 20th October 2007 07:37 PM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 05:20 PM |
| Quick PCB question | Piper | Chip Amps | 2 | 7th March 2005 11:59 AM |
| VERY quick question... | Wyloch | Multi-Way | 2 | 3rd March 2005 05:34 PM |
| Page generated in 0.10233 seconds (77.37% PHP - 22.63% MySQL) with 10 queries |
