diyAudio Sponsor
Old 2nd May 2009, 08:11 PM   #11
analog_sa's Avatar
Originally posted by Shoog
That parafeed cap seems very small. When i messed about with parafeed I always used something around 4uf.
68uF<4uF?
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Transformer-driven SEPP output stage. Circlotron Solid State 10 17th February 2003 05:14 PM
Page generated in 0.05873 seconds (65.44% PHP - 34.56% MySQL) with 11 queries
