| diyAudio Sponsor | ||
#11 |
Of course. The cathodes are strapped. Voltage drop across the 330 R resistors would be meaningless.
A round of 10 ohm resistors for all my pentodes! I can't see any other way to do it besides using a pair of those tube socket adaptors with the internal resistor and test leads, as you mentioned. Thanks again. Great forum here. |
#12 |
I think the balance circuit could be adjusted by using a scope and dummy loads on the speaker taps to monitor for noise that could be added to the cathodes using a signal generator or other source of low voltage AC. The signal would be applied through a cap to protect the test equipment from the DC.
The pentodes in push pull will cancel this noise when balanced and that should be evident on the scope. |
#13 |
Perhaps applying a 20Hz signal (dummy loads attached) and adjusting the pot until you have the least distortion would work well.
| Strange bias drift while cooling | ceharden | Solid State | 4 | 12th April 2009 11:38 AM |
| Strange circuit - heater hum opt feedback? | m6tt | Tubes / Valves | 3 | 23rd April 2008 06:13 PM |
| Strange LTP cascoding circuit | roender | Solid State | 3 | 11th June 2007 10:23 AM |
| strange op-amp circuit | kubeek | Parts | 23 | 15th October 2006 06:25 PM |
| Strange reverb circuit | bembel | Tubes / Valves | 1 | 20th September 2006 04:55 PM |
| Page generated in 0.07163 seconds (71.07% PHP - 28.93% MySQL) with 10 queries |
