Common as dirt on guitar amps.
Most are wired diode cathode to plate, diode anode to ground. One diode for SE, one on each side for PP.
Use a fast recovery type rated at LEAST twice the supply voltage and preferably four times. 3A is a good current (larger diode area is more forgiving).
Cheers!
Cheers!
Wavebourn said:For SE a diode can't help. Rather a bridge with powerful Zener in secondary.
Dummy me for not catching that one
He's right... it'll cutoff part of your waveform.
Cheers!
Sorry for slow responce.
I am wanting to protect my OT's from whatever happens when a output tube goes bad, runaway, blowup, melts internaly, etc..Rectifier going to the bad, me hitting something I should not when probing hot, etc. If I could see a schematic for decent protection for voltage spikes , shorting , to much current, etc. for PP amps, & SE amps, with eather fixed or cathode bias. I would implement them in all my amps. I do have bad luck with output tubes & allways feel lucky when the OT's still work after words. I have read that fuses are not the answer & can be actually worse. I do not know as I am not at the level of knowing if true or not. I just can't imagine everyone with rarer than heck vintage OT or spendy new iron, not protecting them. I never see circuits implementing such protection. Maybe it is all for not & nothing to be conserned about..?
Joe
Joe
- Tubes / Valves
- Diodes to protect OT's..
