diyAudio Sponsor
Old 24th February 2010, 04:36 PM   #61
whitelabrat's Avatar
Yup. 6JD5's.
811A single ended triode power amp | Tube amps DIY
Interesting.
Old 24th February 2010, 05:30 PM   #62
tubelab.com's Avatar
The SV811-3 is NOT an 811A, not even close. The SV811-3 has a Mu of 3, works somewhat like a 300B, and isn't available any more.
I remember a schematic that used a 6V6 cathode follower to drive the grid of the 811A directly. Can't find it now.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 26th May 2010, 04:35 PM   #63
I've been looking at the *FJ7 tube. A pair of those look like they could be good drivers, especially with that hefty 10w side.
I was trying to modify an old Bogen MU15 to use 22JF6's as a guitar amp, but it wasn't happy. So I figure I'll use it as a mule for screen drive testing. I'm guessing the output transformer is rated for at least 15w. I'm not looking for horse power, just a proof of concept so I can better understand the circuit.
I didn't have any suitable transformers to provide 22v to the heaters so I bolted on a 40vac transformer and wired the heaters in series. Got nothing to loose. I get 20v on the heaters which I figure is good enough.
The power supply puts out about 400v on the B+. I figure this is good enough for 15w. I won't mess with 7W7's here. Just 6J6's and either a 6SN7 or a 6CG7 since there are already sockets ready to go.
Ideas for a simple 6080/6AS7 Push-Pull amplifier sonata149 Tubes / Valves 29 20th August 2010 02:54 AM
300B - Push Pull or PSE to drive a commercial speaker arnoldc Tubes / Valves 70 19th February 2008 11:50 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 01:23 AM
Page generated in 5.59938 seconds (1.37% PHP - 98.63% MySQL) with 11 queries
