What is this? What is this? - diyAudio
What is this?
What is this?
Old 28th April 2009, 02:32 AM   #1
astouffer is offline astouffer  United States
astouffer's Avatar
Default What is this?
http://www.synergisticresearch.com/p...nigma/overview
"tube based power supply for Active Shielding"
Well thats a new one for me. I've seen the cables in Stereophile that use a bias voltage to supposedly cut down on noise, but one based on tubes?
http://blog.stereophile.com/ces2008/10708syn/
$6000? For $6000 I will personally chauffeur you to a concert hall every week for one year
Old 28th April 2009, 02:47 AM   #2
Geek is offline Geek
Geek's Avatar
What is this?
More audiophool rubbish
That one doesn't even appear to have the plate cap active.
Good grief.
Old 28th April 2009, 02:48 AM   #3
HollowState is offline HollowState  United States
HollowState's Avatar
Incredible but not suprising. Yet another well hyped toy for filthy rich audiophool lawyers and doctors to pee away their money on.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 28th April 2009, 04:54 AM   #4
kevinkr's Avatar
What is this?
Umm, not that uncommon to use some high voltage gas thyratrons as rectifiers, and in that case the grid is used as the plate and the plate cap is left unconnected. A pair is usually used with FWCT... Not sure if this is what they are doing or not. FWIW this works quite well at a couple of hundred mA and a KV or two... Hope I am not giving anything away..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th April 2009, 09:59 PM   #5
tomchr is offline tomchr  Canada
tomchr's Avatar
I suspect this gizmo will do as much for sound quality as myrtlewood speaker cable stands...
I totally dig their product photography, though... :-)
Tom
Old 28th April 2009, 10:19 PM   #6
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
What is this?
Bootstrapped shield most probably. I used such a trick in a long cable snake to connect guitars directly to the mixing console.
The Devil is not so terrible as his math model is!
Old 28th April 2009, 11:23 PM   #7
Hearinspace is offline Hearinspace  Canada
What is this?
Isn't biasing an interconnect more or less the same idea as biasing crossover capacitors ?
Old 2nd May 2009, 09:48 AM   #8
jamesjung21 is offline jamesjung21  New Zealand
jamesjung21's Avatar
Interesting to see that the 323A's top cap isn't even connected to anything.
Sorry for going off-topic, but isn't it funny to imagine what Apple Inc.'s lawyers will do once they see the Synergistic Research web page layout? I'm pretty tempted to let Apple know
Old 2nd May 2009, 11:43 AM   #9
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
The first sentence of the article explains exactly what the thing is:
"Sculpted as a work of industrial art..."
Old 2nd May 2009, 05:51 PM   #10
pointy is offline pointy  United Kingdom
pointy's Avatar
a half working doughnut toaster with a sod using it pop up button
What is this?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
