diyAudio Sponsor
Old 27th April 2009, 07:50 PM   #1
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default aikido/807PSE and local feedback
I want to make a poweramp with 6sl7 +6N6p aikido at the front, followed by two parallel 807 tubes in pentode se configuration.
I suspect some feedback would be handy and I like the local variant of it. Could I copy the solution of the T-rex 300B amp ? Here a 47K resistor and a 2 uF cap are in series between the plate and the grid of the 300B. I suppose that the designers know what they are doing. I don't, so my question is can i use the same solution and the same values of components for the parallel 807's ?
Old 27th April 2009, 08:16 PM   #2
aardvarkash10's Avatar
Default you just described a parallel RH807
plenty recently about this subject - check out Alex's website for the 807 version including the schematic. http://www.tubeaudio.8m.com/807/807.html
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 28th April 2009, 07:54 AM   #3
Jaap's Avatar
Default Re: you just described a parallel RH807
Problem is that i want to build with an aikido frontstage. That is a different concept than the RH idea (which i already tried with el84)
Cascode with local feedback croccodillo Tubes / Valves 8 19th July 2007 03:30 PM
How to accomplish local feedback in pp amp ? Jaap Tubes / Valves 11 7th December 2006 05:04 PM
a question about local feedback hacknet Tubes / Valves 8 16th August 2005 06:42 AM
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 08:03 AM
Page generated in 0.06762 seconds (69.76% PHP - 30.24% MySQL) with 10 queries
