Repairing paper in oil caps. - Page 2 - diyAudio
Old 27th April 2009, 11:18 PM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally posted by DHT112A
Whether or not you like PIO why even attempt to repair a cap??????
Costs of advertising were so big so such caps are very expensive.
The Devil is not so terrible as his math model is!
Old 28th April 2009, 01:36 AM   #12
HollowState's Avatar
Originally posted by dsavitsk
It's a strange thing -- people who don't like PIO caps and thus who don't use them often say the reason for this is that the highs are rolled off. However, people who do like them often note the reason for this is due to the the sparkle and extension in the high frequencies.
Yo Dave,
While it's true that I don't use PIOs very much, I can't really say that I don't like them. I have mixed opinions regarding them. But here is an example of why I said what I did.
About thirty years ago I built an Ampex 351 recorder from scratch. (Well almost as I bought motors and heads.) I couldn't afford even a used unit, but I was working in a machine shop and had access to the equipment. The electronics used all Sprague capacitors that were oil and paper like the originals. Resistors were carbon comp. I still have the working machine.
Years after that I got to reading how plastic capacitors were much better for audio from the Walter Jung artical in Audio Magazine. So I decided to replace some capacitors to improve the sound. After replacing most of the coupling caps with polyesters, I was shocked at what happened. The high frequency response was peaked so much that the playback compensation adjustment had to be set full over to make it reproduce correctly. And the record preemphasis was similarly too high. All because of going from paper to plastic capacitors in the signal path.
Sound crazy? Not really, because other parts of the circuit were designed for the response of the slower paper caps. They can't be that bad because all of those old Mercury Living Presence and RCA Living Stereo recordings that audiophiles swoon over were made on those vintage Ampex machines.
"The further a society drifts from the truth, the more it will hate those who speak it" ~George Orwell
Old 28th April 2009, 01:49 AM   #13
TubeHead Johnny's Avatar
I have no problem with PIO's. But adding ANY old cap in a new or restored tube circuit is not a good idea.
Old 28th April 2009, 06:49 AM   #14
Shoog's Avatar
I had them and like the sound when appropriately bypassed. I stupidly forgot to check their integity before I installed them on the top of the case. It is no big deal to replace them with some 4.7uf MKP's I have, but the case is riddled with holes from them. I did have spares but I gave them to a friend.
I will probably mount the MKP's under the case and leave the PIO on for show. Lessons learned - check your caps.
Shoog
Old 28th April 2009, 02:40 PM   #15
Lesson learned - check your caps.
Being technically deficient, can I ask a stupid question:
How do you check capacitors for leakage?
I have quite a few old stock PIO capacitors but was always afraid to use them having read negative comments about them.
Thanks.
Joe A
Old 28th April 2009, 02:44 PM   #16
ke4mcl is offline ke4mcl  United States
i've used vintage PIOs on lots of my projects. the ones i use are high grade stuff though. sprague vitamin Q or NOS military stuff. havent had a problem yet. I've read that PIO's can be the longest lived of all caps next to silver micas providing the seals aren't compromised.
to address the self healing comment...
self healing caps are NOT new. i have a QST (amateur radio) magazine from the early 1930's that has a full page ad for aerovox capacitors that self heal.
certified packrat
Old 28th April 2009, 07:54 PM   #17
pointy is offline pointy  United Kingdom
pointy's Avatar
if you do use car oil to bring them back to life don't use one with teflon or magnatech type.
because........!
Old 28th April 2009, 08:49 PM   #18
Sheldon is offline Sheldon  United States
Make a case for the new caps and hide them in there. If your caps weren't PCB, I'd remove the guts and put a more compact modern cap inside. Maybe you can find a cheap non-pcb cap to serve as a container donor.
A simple way is to put a resistor in series with the cap, put DC voltage across the two, and measure the voltage across the resistor. Calculate the current by ohms law. You want to use at least the voltage the resistor will see in the circuit. You can use the circuit supply for this. Use a resistor value around 5/C. You can use less, but the resolution will be lower.
Here's a more detailed description of a similar method: http://www.angelfire.com/electronic/...ting_caps.html
Sheldon
Old 28th April 2009, 09:02 PM   #19
Shoog's Avatar
If you have a good cap to compare it with a simple method is just to check it with a digital multimeter set to the 2meg ohms scale. The l,eaky cap will take a lot longer to rise than the good cap.
So I replaced the oil caps with some big juicy 4.7uf MKP's. The overall tone is similar, but everything is a bit tighter sounding. At the moment they are just bolted to an available corner of the case and I will work out where they will end up when I have sorted out what I am going to do with the PIO caps. I was thinking of adding a VSPS on top of the case. I built one of these before and was really impressed. I am currently running a Tube phono but never really got it quiet enough for my liking. I could try the FVP5 phono stage which would partner with the SLCF preamp.
Cheers all.
Shoog
Old 29th April 2009, 06:03 AM   #20
limono is offline limono  United States
Now, My friend has a pair of silver jensens one shorted and one leaky. These retailed I believe at $500-600 a pair. Maybe he sholuld try to "rewind" them??
Paper-oil caps for sale nafanja Swap Meet 0 28th March 2008 06:43 PM
Big Paper in Oil Caps chrish Tubes / Valves 10 24th September 2007 08:33 AM
WTB/WTT PIO (Paper in Oil) Caps Andypairo Swap Meet 1 10th February 2006 07:19 PM
Paper in oil caps Jonathan Bright Parts 1 11th March 2005 10:51 AM
Paper in Oil caps - any good? Paulr Parts 4 20th August 2003 10:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
