diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Optoisolator compressor ideas (http://www.diyaudio.com/forums/tubes-valves/143042-optoisolator-compressor-ideas.html)
flysig 27th April 2009 04:00 PM
Does anyone have some simple implementations of a compressor using an optoisolator?
I'm thinking about using the LED as the cathode bias and then the resistor in a feedback loop. Though the datasheets say that the photoresistor needs at least 1 mA current to get a reliable resistance. The photoresistor would be used for Rf in the following (pic from Valve Wizard's site)
http://i22.photobucket.com/albums/b3...edback1jpg.jpg
So maybe a better implementation is the resistor in the cathode bias and the LED somewhere else?
Or how about the photoresistor used as part of the screen bias of a pentode?
This cool optoisolator must be good for a simple insertion into basic circuits.
Wavebourn 27th April 2009 06:51 PM
I use LED to sense screen current in output tubes, a photo resistor forms a simple voltage divider with a resistor on the very input of the power amp. It is an anti-clipping compressor I use in all my tube power amps.
Michael Koster 28th April 2009 02:36 AM
2 Attachment(s)
This reminded me of a project I started before The Big Move. It's
an opto compressor using an LED and CdS sensor. The LA-2A
and LA-3A use a phosphor panel but these wear out.
I found an LED close to the bright green color the CdS sensors like
best, and fit them together using adhesive coated heatshrink.
I then plotted CdS cell resistance vs. LED current and voltage (the LED
part has a built-in resistor) and was surprised to find it, while not
strictly linear, to be controllable over a 30 db range or more in an
attenuator circuit.
Anatoliy, that's something I'll have to try. do you use a CdS sensor;
what about time constant?
Michael
flysig 29th April 2009 07:37 PM
Now that is really slick. It took a while for it to sink in but that is an elegant idea.
Wavebourn 29th April 2009 11:47 PM
No, I use Vactrol.
It's too fast to be used as a fair musical compressor: on low freqs outputs get clipped, but the amp itself does not clip.
Wavebourn 30th April 2009 12:27 AM
It's Ok, Sometimes it takes few years until people start digging my schematics and constructions that look foolish at first sight. :cool:
Copyright ©1999-2017 diyAudio
