Airgap for filament transformer ?
Old 29th April 2009, 02:51 PM   #11
Funker is offline Funker  Germany
Hi Johann,
all other member explained already before what the possible reason for the unwanted xfmr heat up .
To find what the troble occur from , disconnect the HV secondary from the rectifer tube. Insert an Ammeter in the heater xfmr primary an turn the amp on. Take a little time until the rectifiers filament is warm up. Remeber the primary current . Now turn the amp off and replace the HV secondaries to the rectifier tube. Turn the amp on and check the primary current of the heater xfmr once more. If there is a different of both measured currents, you will have probably a problem with a core load due dc bias. I do not think there is an isolation leak , because that would blow the HV fuse and ruin your retifier tube immediately .
good luck !
regards from Hamburg
Ground your devices before they ground you
Old 29th April 2009, 05:41 PM   #12
myster_maze is offline myster_maze  Greece
Did you measure the two secondaries of the filament transformer separately?
If they're not exactly identical ie 2.5V, this may cause a small DC current that saturates the core.
This happens if the two windings are not in parallel but in series. You can measure the resistance of each winding, too.
If one is higher than the other...
....there's no other way than taking the B+ from the end of the winding and not from the CT.
An air-gapped core will help but it's not THE solution.
Airgap for filament transformer ?Hide this!Advertise here!
Filament Transformer dejanm Tubes / Valves 11 26th December 2013 02:21 AM
Filament Transformer for 26 DHT korneluk Tubes / Valves 7 8th January 2008 06:25 PM
WTB: 6.3V Filament Transformer mrdon Swap Meet 1 20th March 2006 02:36 AM
Filament Transformer cantskienuf Tubes / Valves 1 24th June 2005 01:41 AM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
