diyAudio Sponsor
Old 26th April 2009, 10:18 PM   #1
Default is there a typo in the Tubelab SE schematic?
I'm trying to figure out the wiring of the capacitors of the Tubelab SE. The schematic has C2 connected with negative being grounded and positive carrying the current to V2/V3. The board looks like it has this reversed. The positive is grounded on the board. So is there a typo on the schematic?
TIA
Old 27th April 2009, 12:14 AM   #2
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I believe it's the schematic that's wrong. I remember noticing this too. When using 5V filaments, this cap is shorted and the four diodes act as a bridge for both the 5842s and the 300Bs. When setup for 2.5V filaments, the diodes act as full-wave rectifiers. To make up for the lower voltage going to the 5842s from the Schottky bridge, D4 and D5 act as another bridge and provide a negative DC supply to make up the difference.
Russ
Old 27th April 2009, 12:38 AM   #3
isaacc7 is offline isaacc7  United States
I'm pretty sure George has mentioned this on his website, maybe in the construction manual...
www.isaharr.com
Old 27th April 2009, 01:27 AM   #4
tubelab.com's Avatar
OOPS. I don't remember seeing this one before. The schematic is indeed wrong. The positive end of C2 should be grounded. I will fix the schematic ASAP.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 27th April 2009, 02:12 PM   #5
Thanks! I didn't see it on the website - just thought I'd double check to make sure my understanding is correct.
46 and the Tubelab SE w5jag Tubes / Valves 8 18th May 2009 07:52 PM
tubelab se DimZ Tubelab 58 20th January 2009 12:47 PM
tubelab PP? weinstro Tubes / Valves 9 25th March 2008 03:07 AM
tubelab ethermion Tubes / Valves 24 20th July 2006 03:13 PM
Page generated in 0.06715 seconds (72.65% PHP - 27.35% MySQL) with 10 queries
