| diyAudio Sponsor | ||
I have a vandersteen subwoofer (that I won't be using with my new stereo (full range open baffle with Hframe 18 inch woofer)
The Vandersteen uses a cap at the input of the amp for a high pass cross over 6 dB / octave. I am planning on a plate amp for the woofer. It will have its own active crossover for the bass (around 200 Hz) Is there any advantage for the amp It will be (haven't got it started yet) a tubelab simple SE with Kt-88> Seeing is how this is just a few watts, is there an advantage to the amp or sound to do this kind of cross over over a conventional crossover right on the speaker? And also, wierd question, could I do this input cap on amp at 200 Hz and add a 6 db crossover on the speaker at this or some other point to effectively make a 12 dB crossover? (if I ended up thinking the 6dB input cap wasn't enough) Thanks, Paul |
| Input transformer: floating input = distortion | ErikdeBest | Tubes / Valves | 13 | 20th January 2009 09:36 AM |
| HELP: BJT input op-amp's input bias current compensation | frickecello | Solid State | 6 | 19th June 2007 12:00 AM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| electronic crossover input impedancce | substrate | Solid State | 2 | 4th February 2005 11:26 PM |
| Resistor-Input vs. Choke-Input vs. Cap.Multip. | Blitz | Pass Labs | 13 | 26th September 2003 04:59 AM |
| Page generated in 0.05126 seconds (73.00% PHP - 27.00% MySQL) with 10 queries |
