diyAudio Sponsor
Old 26th April 2009, 10:21 AM   #1
Question Audio Transformer/Cathode Feedback Info
Hi, tube folks,
I got an opportunity to order a pair of custom-built audio transformers. So my idea is to replicate rare yet highly regarded for its sound quality Sansui AU111 amplifier. Its primary windings have additional section for cathode feedback. Something similar is used in McIntosh tube amplifiers.
Does anyone have (or can just guess) technical data for this transformer? I think its pretty standard for 6L6GC/EL34/6550/KT66 push-pull design.
The question is this additional section for cathode follower - what % of primary winding it should be?
Any other data about material core, winding separation, etc is very welcome.
Old 26th April 2009, 01:06 PM   #2
7-8 % from primary coil for 1 tube....
Old 26th April 2009, 03:40 PM   #3
kevinkr's Avatar
Check with Hashimoto Japan - they might even have the information on their website. They made the Sansui transformers, and IIRC made this transformer in the recent past. (Maybe for the reissue amp.)
www.kta-hifi.net
Old 26th April 2009, 07:46 PM   #4
Hi, Kevin! Thanks for suggestion! I know about Hashimoto, checked their reseller www.acoustic-dimension.com and found no transformers with cathode feedback winding. They also sell Tango and Tamura, the same story, only standard generic trafos.
BTW, what is IIRC?
Old 26th April 2009, 09:13 PM   #5
kevinkr's Avatar
BTW, what is IIRC?
In no particular order IIRC - "If I recall correctly..."
AND
Here is another website you might want to check out for Hashimoto (and only Hashimoto) Transformers: http://www.tube-amps.net/index.htm They are directly affiliated with Hashimoto and you can purchase AU-111 output transformers directly from them. This is a link to the OPT-111 which is the AU-111 replacement output transformer, unfortunately it is currently out of stock: http://www.obsinc-products.com/servlet/Detail?no=10 (Note: Obsinc-products.com hosts tube-amps.net) Perhaps someone closer to you can also source this PN..
www.kta-hifi.net
Cathode feedback and DHTs jane Tubes / Valves 13 1st July 2009 09:54 PM
Simple SE cathode feedback... oldmanStrat Tubelab 9 1st May 2009 07:51 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 08:07 PM
Cathode Feedback How-To? sorenj07 Tubes / Valves 4 23rd October 2007 05:04 AM
Cathode feedback mark_titano Tubes / Valves 20 11th August 2005 01:56 AM
Page generated in 0.10143 seconds (76.25% PHP - 23.75% MySQL) with 11 queries
