diyAudio Sponsor
Old 24th April 2009, 05:14 PM   #1
pwan is offline pwan  United Kingdom
Default "Bevois Valley" in triode, what to do with the feedback?
Hello
If I wired "Bevois Valley" in triode (using 560 Ohm Rk), what to do with the feedback?
A. Leave the current one as is
B. Remove them out ( i.e. no negative feedback)
C Adjust the value of feedback (if then, to what value?)
Thanks.
Old 24th April 2009, 05:58 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
According to the Mullard data sheet, you get 5W out of PP triode-connected EL84. In voltage terms, that's really not much different to 10W, so why not just try the feedback as is and see whether you like it?
To remove the feedback, undo the end of the feedback resistor going to the output transformer and connect it directly to ground.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Morgan Jones's Bevois Valley amp... nickds1 Tubes / Valves 49 23rd May 2012 06:23 AM
PP EL84 Build Questions (Bevois Valley) cgrums Tubes / Valves 19 16th July 2008 06:37 PM
Bevois Valley Design Question cgrums Tubes / Valves 32 9th July 2008 01:20 PM
Bevois Valley and parallel push pull pbholmen Tubes / Valves 11 3rd November 2007 02:44 PM
Kofi Annan in: "Oscillatin' in the Bevois Valley'" Kofi Annan Tubes / Valves 88 21st July 2007 10:16 PM
Page generated in 0.06114 seconds (66.87% PHP - 33.13% MySQL) with 10 queries
