Old 23rd April 2009, 10:26 PM   #1
pazo is offline pazo  Croatia
Default Blowing output transformer
Is possible destroyed output transformer of valve amplifier .
For example if you turn on aplifier without speaker. Push-pull desing with two 6L6 gc otput tubes.
Old 23rd April 2009, 11:25 PM   #2
Send a message via AIM to DigitalJunkie
Is it possible to fry an OPT? Yes.
Running a tube amp without a load is a bad idea because the voltage swing on the primary leads can be very high.It might arc over in the output tube(s),or arc over on the transformers primary windings and ruin the OPT.Some amps may even oscillate or show other odd behavior with no load attached.
Another potential cause of a fried OPT is over current.This might happen from running the output tubes with too much bias current,or if one (or both) of the output tubes lose bias voltage,and go 'full tilt',thus running way too much current through the OPT primary and tube(s) until finally something gives. The excessive current draw may even stress the power transformer(and the rest of the PSU) to the point of failure.
Old 24th April 2009, 02:21 PM   #3
Thanks for explanation.
Old 24th April 2009, 02:24 PM   #4
bigwill is offline bigwill  United Kingdom
General Nuisance
B+ fuses are a very good thing
Toroidal Transformer blowing fuses emperor Parts 15 6th November 2011 05:30 PM
Transformer fuse nuisance blowing halfgaar Parts 16 10th September 2006 10:53 PM
Velleman K4040 is Always Blowing Output Tubes GeorgeK Tubes / Valves 24 29th August 2006 04:27 PM
Leach amp blowing NPN output transistor! supernet Solid State 3 29th June 2002 11:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
