diyAudio Sponsor
Old 23rd April 2009, 02:29 PM   #1
Default Help with 6SN7 w/ CCS
I have about 185V B+ for a 6SN7 input stage in my headphone amp. I started with the CCS set to 9mA, LED bias -2V which gave a Vp ~130V. Does this seem decent?
This is my first ever scratch design and the sound is pretty good, but there is some harshness and is very un-tube like, and very obvious. This is not a taste issue. I expected to have issues with it being too warm sounding but it's the opposite. I want to rule out this OP as a problem before I look at the output stage.
TIA.
Old 23rd April 2009, 02:39 PM   #2
analog_sa's Avatar
Default Re: Help with 6SN7 w/ CCS
6SN7 is like that. Some people really dislike it.
Old 23rd April 2009, 03:04 PM   #3
DougL is online now DougL  United States
-2 volts on the cathode will only allow about a 64 Vpp output before grid current on the 6SN7. That's only about 20 V (minus CSS stall) from hard clipping of the stage.
To Check my math, -2V bias is a max input of 4 Vpp. Since CSS loaded, Av = Mu = 16, so 4 * 16 = 64 Vpp
130 Vp+ -(64/2)V = 162 Vp Max, 98 Vp min.
The rest of your circuit would be helpful.
If you need more than 10 Vrms for your finals, you probably need to re-design your input stage. If possible, higher B+ might allow more bias voltage.
Sorry for the drive-by.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 23rd April 2009, 04:01 PM   #4
Hi guys,
analog_sa, I've had a couple of 6SN7 linestages in the past and none were anything but warm sounding, very different than what i'm getting now.
DougL, thanks for your time.
I have a headphone amp where each channel is a SE triode-strapped 6G6-G output tube, with one 6SN7 triode for input and drive duty. I don't have a schematic to post because I dont' have software.
Also, when is a Rg necessary? I've looked at various 6SN7 pre schematics online and some have the grid to the 100K volume pot and some have a 470K to 1M resistor for example. Is this just for safety if a pot fails?
Old 23rd April 2009, 11:09 PM   #5
If you need to draw a schematic, you can use these symbols.
Joel Tunnah Vacuum tube audio
Very unusual, and Very cool Output tube.
Rg is necessary if you use a classic potentiometer because they could fail open. Not as necessary with a stepped attenuator, but still a good thing.
Doug
Old 24th April 2009, 12:05 AM   #6
SY's Avatar
Way too low. 6SN7 needs volts. With that limited B+, you'd be better with something like an ECC88. The harshness you hear could well be grid current distortion.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 24th April 2009, 12:40 AM   #7
I'm happy to try a different twin triode but I'd prefer an octal if possible. Know of any that are suitable?
I saw a schematic by dick olsher that shows a ~B+ of 205V and 4.5K Rp, and 157Vp. Rk is 300R for -3V. After seeing this I thought I might be OK.
I also noticed the heaters are at 6.75V so I'll fix that up too.
Old 24th April 2009, 12:45 AM   #8
SY's Avatar
160V at the plate is a reasonable value. I wouldn't go lower. At that voltage, you'll want more like 3-3.5V at the cathode.
4.5k plate load? That's an effects box, not an amplifier!
Old 24th April 2009, 12:59 AM   #9
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
I'd first try ditching the CCS if your going for a warm sound.
Old 24th April 2009, 02:43 AM   #10
Here's the initial schematic.
I've change the LED to a 360R which brings about -3.25V and Vp to 144V or so. I couldn't hear any noticeable difference.
Again I don't think this is my opinion of the sound quality, it's not a taste thing - rather it sounds like there is something not quite right.
6SN7 pre-amp Andersen Tubes / Valves 57 17th July 2011 06:00 PM
SE 6SN7 amp.... JandG Tubes / Valves 24 6th March 2011 11:37 AM
6sn7's irishguy170 Swap Meet 0 15th January 2008 07:09 AM
Help me.......What is the 6SN7 ??????? cd149dc Tubes / Valves 10 17th June 2007 04:09 PM
Is it the 6SN7 or me? arnoldc Tubes / Valves 4 12th October 2006 11:31 PM
Page generated in 0.12530 seconds (82.86% PHP - 17.14% MySQL) with 11 queries
