Troubleshooting hum in 12b4 preamp.. finally almost done!!
Old 21st October 2010, 06:32 PM   #11
240z4u is offline 240z4u  United States
Send a message via AIM to 240z4u
Alright, still haven't conquered this problem. I am not totally sure where to start. It is a 60 cycle hum and varies with volume. I am in the process of star grounding the entire preamp, hoping that will help. The umbilical is about 3' long. Is this a problem? I read in another thread that the filter caps should not be that far from the CCS.
Can I look for hum with a multimeter on the PSU without it hooked to the preamp? I read someone was able to do that as well. I assume I am just looking for AC voltage on the B+ line.
I have already converted to DC heaters.
Thoughts? I am going to continue the star ground setup tonight. I am also wondering if my ground wire from the preamp to the PSU chassis is large enough to create a quality ground. I don't recall what the gauge is, but it's not very large.
Thanks everyone.
Evan
Yeah... it seemed like a good idea at the time.
Old 21st October 2010, 06:51 PM   #12
Going to start here; http://www.raleighaudio.com/Audio%20...connection.pdf
Great article!
Old 21st October 2010, 06:58 PM   #13
scott17 is offline scott17
Did you try to simulate your power supply using PSU Designer?
I noticed from the photos that your heater wiring appears to be giant antennas floating through the build, but you said that you have converted to DC filaments. How well filtered is the DC filament supply? The heater wiring could still pose a problem.
Old 21st October 2010, 07:03 PM   #14
I didn't come up with the PSU on my own so I don't know if it was modeled or not. I used the schematic that Eli Duttman provided along with a CCS that bandersnatch designed.
My DC filaments aren't all that well filtered. Eli indicated in a PM that I shouldn't even have had hum with AC heaters. I think I may go back to the AC setup honestly since my DC isn't really filtered. The hum didn't change when I switched from AC to DC if memory serves.
In this situation, what is the best way to handle running the heater wires through the chassis without turning them into a huge antenna? Ill run the damn things through tubing as a shield if I have to!
Thanks for the response, I really appreciate it.
Evan
EDIT; Embarrassingly enough, I may have installed a small switching power supply for my heaters. Stupid noob. Ill re-install the AC heater setup.
Old 21st October 2010, 07:21 PM   #15
The best way to run the heater wiring is to have it "hug" the chassis and keep the leads as short as possible. It should be run as close as possible to the chassis. The heater wiring should also be twisted as tight as possible for best hum cancellation. All small-signal wiring should be kept as far away as possible. Any signal wiring that has to cross the heater wirings path should cross at a right angle.
Edit: Based on the photos, I would re-twist your heater wiring into a much tighter twist.
Evan
Old 21st October 2010, 07:22 PM   #16
Alright, I can certainly handle that. Thanks.
Old 21st October 2010, 07:32 PM   #17
Here is a photo of an amp I built. Although it is not just a preamp, you can see the amount of twist in the heater wiring and I have absolutely no hum.
Also, if you have the component values and voltage/current measurements for your build, you can input these values into the PSU Designer II program to check for possible power supply hum.
I doubt this is the case though as the individuals you mentioned as helping you with this are highly respected in the DIY community and would have certainly noticed if there was a power supply issue.
Good luck.
Old 21st October 2010, 07:34 PM   #18
Good luck.
Forgot to attach, so here it is.
Old 21st October 2010, 07:36 PM   #19
Oh wow, my attempt at twisting is pretty lame!
I really appreciate you taking the time to get me pointed in the right direction. As of tonight I am going to;
Star ground everything
Replace AC transformer for heaters
Twist heater wire tightly.
I read the PDF about grounding and Ill do my best to implement that and report back.
Evan
EDIT; Amp looks very nice btw!
Old 21st October 2010, 08:07 PM   #20
Doz is offline Doz  United Kingdom
Doz's Avatar
Evan
I use one of those small electric drill screwdrivers with a hook in the chuck to twist the heater wiring, it's quick, tight and easy.
Troubleshooting hum in 12b4 preamp.. finally almost done!!Hide this!Advertise here!
12B4 Preamp philipbarrett Tubes / Valves 132 14th October 2017 11:53 PM
WTB: 12B4 Tubed Preamp. Zekk Swap Meet 0 18th March 2009 03:17 PM
12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) DougL Tubes / Valves 3 2nd August 2004 06:06 PM
