diyAudio Sponsor
Old 21st April 2009, 06:29 PM   #1
Default SE cathode bias question
Generally speaking, does a higher plate current cause a harder/brighter sound? Does a lower plate current cause a warmer/rounder sound?
I have a SE amp I want to tweak but not sure which way is logical.
Thx
Old 21st April 2009, 06:34 PM   #2
SY's Avatar
No and no. I think you'll have to experiment on your particular amp.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st April 2009, 07:53 PM   #3
rdf is offline rdf  Canada
rdf's Avatar
Originally posted by SY
No and no.
Within limits of the supporting components (OPT, etc.) and assuming the tube isn't being biased poorly, I've always found higher currents through triodes correspond with lower second harmonic at the expense of raising higher harmonic components. That generally matches the bright-harsh/warm-round description. Of course, this also ignores plate impedance, harmonic cancellation, feedback, etc..
Absolutely.
Ears aren't microphones.
Question about Cathode bias in this Magnavox amp. . . Nihilist Tubes / Valves 3 21st January 2009 07:33 PM
cathode bias circuit question gary h Tubes / Valves 14 26th August 2008 12:36 AM
Lab supply for cathode bias experiment question.. JandG Tubes / Valves 2 14th August 2008 01:37 PM
newbie question about 7591 cathode bias joshuahhhhhhh Tubes / Valves 3 9th December 2007 04:33 PM
Page generated in 0.06000 seconds (74.95% PHP - 25.05% MySQL) with 10 queries
