Hello everybody,
I'm going to build a power amp output 3.5w/channel from cathode with one 6080. I need help here before I go... Any ideas ? Many thanks in advance. Singh |
#2 |
The trick, as always with CF output stages, will be getting a very linear, very high voltage capability driver stage. This will not be a trivial undertaking!
If there's a sucker born every minute, where do the rest of them come from? |
#3 | |
I like tricks.I'm working on shrinking a schematic file,will post later. Cheers! Singh |
#4 | |
Here's the schematic I'll follow. |
#5 |
Its not as hard as it sounds to get a good linear driver for the 6080. These tubes are at their happiest when run hard and low. I have had great success running them at 100V and 100mA, which gives a drive of about 60V Peak to Peak - which is well in the capabilities of most driver stages.
Shoog |
#6 |
[QUOTE]Originally posted by Shoog
[B]Its not as hard as it sounds to get a good linear driver for the 6080. These tubes are at their happiest when run hard and low. I have had great success running them at 100V and 100mA, which gives a drive of about 60V Peak to Peak - which is well in the capabilities of most driver stages. Hi Shoog, Thank for your advise. Cheers! Singh |
| cathode follower | vlljpior | Tubes / Valves | 6 | 22nd March 2005 07:50 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 03:12 PM |
| Cathode Follower? Yay or nay? | SHiFTY | Tubes / Valves | 25 | 16th March 2004 06:38 AM |
| cathode follower | olvrkrg | Tubes / Valves | 3 | 21st February 2004 09:49 PM |
