8ohm speakers 4ohm tap - diyAudio
Old 17th April 2009, 04:29 PM   #1
5u4 is offline 5u4  United States
5u4's Avatar
Default 8ohm speakers 4ohm tap
When I built my 2A3 Loftin-White I ordered 3K Pri with single 4ohm secondary OPT's from Electra-Print as at the time, I had 4ohm Klipsch speakers that I thought I'd never get rid of, well I got rid of them & now have 8ohm speakers. Seems to sound okay, but can't help wondering if I should order new OPT's with 8ohm secondary.
If I got this right, I'm essentially loading the 2A3 with an effective 6K load with the consequences of:
Less power
less distortion
less amplifier output impedance
I suppose there's more to it than that as speaker impedance is usually all over the place.
Old 17th April 2009, 11:22 PM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
You've answered all your own questions correctly. If you're getting sufficient output power for your needs, why go to the expense of changing it?
4ohm and 8ohm LR4 xo LukeDuke Multi-Way 1 17th April 2008 05:09 PM
4ohm speakers for 8ohm application? SikSS Full Range 4 15th December 2007 04:09 PM
8ohm or 4ohm? adrrad Chip Amps 5 21st October 2007 04:29 PM
4ohm Sub driver to 8ohm Sub amp? WBFAir Multi-Way 10 31st March 2007 01:29 AM
4ohm Car Speaker to 8ohm Use? PrecisionAudio Car Audio 1 20th April 2006 02:40 AM
Copyright 1999-2017 diyAudio
