| diyAudio Sponsor | ||
#11 |
bereanbill
The last poster nailed it pretty well, you can fix that hum.! and congrats, lots of fun. Is it loud enough |
#12 |
I'll try the artificial centertap to the cathode...that is referenced to ground anyway....And Firechief...thanks again, man. You helped me with a breakthrough I've been chasing for a couple of months now. Yeah, it's loud enough for what it is...but is it ever REALLY loud enough? I think my next project ir going to be a JTM45 clone...already have the trannies and chassis. To be continued.....
#13 |
Hi Bereanbill,
I have built one of these and it hums as well. None of my other amps do. I put it down to the power caps. They are simply undersized for the job. I haven't got a schematic at hand for the Deluxe c but the 'd' (which is the one that I built) only uses 16uF caps. Don't all guitar amps hum? Cheers, Rob |
#14 |
Yeah, I think all Fenders are under-filtered. I always bump the plates and screens up...double most times...but preamps may change the tone, so I don't usually change those. I used 22u in this guy..wanted to go bigger but the board was only so wide. I think mine is the PT being too close to th outputs. I'll move that first and then try the filaments.
And I guess when you change a circut as much as I did this one, you run that gamble...but no, not all amps hum. I just got a little Lindell amp...voltage dividing circut, 50C5, 12AU6, 35W4...it hummed so badly that no signal came thru. I recapped it using a mish-mosh of stuff I had around, doubled the plate filters, bumped the screens, and it is DEAD quiet. So I guess with a higher gain circut, you have more risk of hum...more gain=more hum??? "But the frustration of failure is always eclipsed by the thrill of sucess"...I said that !!! |
| Help a noob build Pedja Rogic's J-fet buffer | mattjk | Chip Amps | 5 | 29th July 2008 04:10 AM |
| [noob] Looking to build a really, really small sub | Lindell | Subwoofers | 18 | 13th November 2007 03:16 PM |
| Help a noob build a ZV9 | neil_kaye | Pass Labs | 63 | 15th March 2007 01:18 PM |
| Diy noob want to build monoblocks. | christianlie | Solid State | 3 | 11th December 2006 07:57 PM |
| Page generated in 0.09117 seconds (68.76% PHP - 31.24% MySQL) with 10 queries |
