diyAudio Sponsor
Old 24th April 2003, 06:08 PM   #1
Send a message via ICQ to HenrikKronborg
Default Audio Innovations Series 300
Hi all tubelovers
A friend of mine got his hands on this little amp.
The problem is, that after a (very) few minutes, it starts to hum. Quite loud in fact. Changed all the electrolytic caps, they looked kinda done
The hum is still there and I noticed that one of the tube lights more than the others. I believe it's a push-pull amp, so there should be some balance in it.
My quess is, that the tube needs to be changed, but since i'm not into tube ( not saying i don't like them ) i thought i'd ask in here
/Henrik
Old 24th April 2003, 06:30 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Hmm,
What's the valve line-up?
The output valves look like ECL86..
Old 24th April 2003, 06:45 PM   #3
Default Output valves
John,
Sorry, forgot all about the valves. Your hawkeye tell you right.
ECL86 it is
I have the schematic at work. Will post it tomorrow
/Henrik
Old 24th April 2003, 06:59 PM   #4
dhaen's Avatar
Default Hawkeye? Well...
Henrik,
It's not such a feat. The ECL86 is the only audio specific triode-pentode that has a half-height triode section. This is clearly visible on your image.
Regarding the hum, is it on one or both channels?
It should be possible to run a channel (with severely reduced performance) with one output valve, for test purposes.
Old 24th April 2003, 07:09 PM   #5
Fuling is offline Fuling  Sweden
Those transformers looks familiar to me.
They look identical to the ones used in the Edison 12 amp.
Made by Partridge, I believe.
I have a couple of those OPT:s and I´m putting them to use in a 6AQ5/EL90 amp.
Old 24th April 2003, 07:23 PM   #6
John,
I will try and find out regarding the hum tomorrow.
Will try and see what happens when removing one of the tubes as well. Do you have any idea what it will sound like?
/Henrik
Old 24th April 2003, 07:39 PM   #7
dhaen's Avatar
Henrik,
Removing one output valve will:
Reduce the gain a little
Cause loss of LF, especially at higher power
Increase distortion
But!... and I hadn't thought of this...
Removing one ECL86 will also remove the triode section which may not be "channelised", so perhaps the sound might dissappear!
Old 24th April 2003, 11:04 PM   #8
diyAudio Senior Member
fdegrove's Avatar
Default AI.
In case weren't able to help you out:
BORDER PATROL.
Frank
Old 6th April 2004, 08:59 PM   #9
Stig is offline Stig  United Kingdom
Default Re: Output valves
Originally posted by HenrikKronborg
John,
ECL86 it is
/Henrik
Is that Audio Innovations Series 300 schematic still available?
Audio Innovations Series 500 problems Jon Bradbury Tubes / Valves 50 15th November 2011 01:50 AM
Audio Innovations series 800 reactivation + some mods Basill Tubes / Valves 3 11th December 2008 02:03 PM
Audio Innovations Series 200 Phono Stage Thomo Tubes / Valves 1 19th January 2008 02:54 PM
Audio Innovations 800 (series 2) Mr. Triatic Tubes / Valves 5 12th February 2004 10:15 PM
Audio Note Kageki vs. EAR 859 vs. Audio Innovations: The First Vortex Tubes / Valves 1 2nd February 2004 12:31 AM
Page generated in 0.09910 seconds (78.61% PHP - 21.39% MySQL) with 11 queries
