diyAudio Sponsor
Old 13th April 2009, 05:07 PM   #1
Question 6n6p transformer output impedance
hi
due to the fact that I am a beginner in (tube)electronic stuff,
my first lesson was read read read and try to understand.
lesson two: the construction of a tube amplifier is now done.
i am a proud owner of an self made triode pushpull amplifier.
6n2p for the driver section
6n6p in pushpull mode, class a
ez35 for tube rectifying
aprox 3.5 watts of fantastic music fired through my klipsch rf-7.
actually enough power, no doubt
lesson three:
i want to build the amplifier again, but better.
some bad decisions about the position of some parts e.g. the input capacitor´s.
for the first-try-amplifier i used output transformer from hammond (1609) 10K impedance.
to whom it may concern
what is the best primary impedance for the 6n6p 10,12 or 16K ?
thanks in advance
michael
picture 1
picture 2
picture 3
Old 13th April 2009, 06:16 PM   #2
Hi!
Ri 6N6P = apr. 1.8 kohm. For PP - 3,6 kohm
Ra=/3-5/*3,6 = 10,8 - 18 kohm.
10 kohm is good, but
I prefer You 12 or 16 kohm, but You must try and select, if there is
a possibility on sec. coil to connect 4 or 8 ohm for 12 and 16 kohm.
Output transformer impedance question pkjames Tubes / Valves 21 19th October 2009 09:18 AM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Primary impedance output transformer Rob11966 Tubes / Valves 5 2nd June 2008 03:14 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Output transformer Impedance NickC Tubes / Valves 6 9th May 2003 05:27 PM
Page generated in 0.06489 seconds (68.57% PHP - 31.43% MySQL) with 10 queries
