| diyAudio Sponsor | ||
Hi again..anyone have plans for building a variac ? How hard can it be ?
#2 |
Why would you bother? They're cheap enough second hand.
#3 |
I guess just for the sake of accomplishment...
#4 |
I'll have to agree with Brett; there are many other things you can do in this hobby that would fill you with a greater sense of accomplishment for far less money and/or aggravation (custom winding an output transformer or building a line-level preamp both spring to mind).
Just in case nobody has mentioned it, try to attend a local hamfest. I've picked up 10 A variacs fused and in housings for as little as $5 - and I can assure you they're FAR safer and more reliable than anything you can build. |
#5 |
Here is a possible compromise answer :
Buy one of the cheap readily available variacs, you will have a good safe one, as Brett and Zman3 suggest, then copy it, and your desire for a sense of accomplishment will be satisfied.
Robert McLean |
#6 |
I didn't mean to rain on anyone's parade, but for the same effort you could wind your own audio transformers which will teach you more and you'll get a lot more use out of. I use my variac a bit, and on a busy week it'd be lucky to get an hours use.
#7 |
Thanks for the input. Winding trannies is on my accomplishment list, but I don't think I'm quite ready for it yet...baby steps first. I'm kind of a Rube Goldberg-type, so anything is gratifying to me. With the clunkers I have around, a variac will get quite a workout in my laboratory.
#8 |
Some reading for you then.
Turner Audio Educational pages There's quite a bit on load matching, as well as OPT design info a bit further down. |
#9 |
I have to reinforce the sentiment here...
A variac is an instrument of death (anything that connects directly to the mains is lethal) This isn't a good choice for a 1st build. Buy a good safe one and it will help protect you during your other experiments |
#10 |
Any recomendations? I just picked up one as a part of a test equipment buy. It looks to be from the 30's,and the cord appears to have caught fire!
I'm guessing I shoud just junk it. I'd like something newish and cheap. |
| DIY Variac | Tyimo | Solid State | 4 | 6th October 2007 11:18 AM |
| FS 10A variac | woody | Swap Meet | 8 | 16th May 2007 04:38 AM |
| Variac | ben goh | Solid State | 21 | 12th March 2007 06:42 PM |
| Using a variac. | anders.a | Parts | 3 | 4th April 2006 07:12 PM |
| Variac? | Scribble | Pass Labs | 16 | 29th July 2004 02:12 AM |
| Page generated in 0.09312 seconds (76.34% PHP - 23.66% MySQL) with 10 queries |
