| diyAudio Sponsor | ||
Hi, I am switching my guitar amp from 4 6L6GCs to 2 6V6GTs. I'm using the Fender Princeton AA964 as a referance. I've switched the transformer to a Mercury Magnetics Princeton. My question is about negitive feedback resistor. The original value was 100k. The value on the Princeton schematic seems kind of low at 2.7k. I was planning on installing a pot to see what value sounded good, but the 2.7k would be very close to the pot being wide open.
Any ideas on this? Thanks Scott |
#2 |
That Princeton feeds the NFB to a less common location than most guitar amps. And it's a point that is only 47ohms from ground.
My guess is that your 4-6L6 setup was not using that Princeton's phase inverter type. Have you changed the entire setup to match that Princeton, or just the output-tubes' setup? |
#3 |
I've changed just the output tubes and the transformer to match the tubes resistance and give me 8 ohms to the speaker.
So I'll stay away from anything that low and work in the 47k to 100k range. Thanks |
| Eight 807's in Push Pull? | TomWaits | Tubes / Valves | 97 | 21st May 2008 12:13 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Is the Zen really a push-pull? | Kashmire | Pass Labs | 3 | 17th August 2004 09:07 PM |
| Double push-pull versus single push-pull | jraraujo | Tubes / Valves | 19 | 19th October 2002 12:23 AM |
| Page generated in 0.07523 seconds (70.31% PHP - 29.69% MySQL) with 10 queries |
