diyAudio Sponsor
Old 10th April 2009, 07:23 AM   #1
Default Fisher 800c selenium rectifier pictures
I did a search and got why to change and how to change so
can someone post pictures of the 800c selenium rectifier so I can tell if mine is original I have a square bridge about 1 inch maybe a tad bigger square and maybe 3/8th inch thick mounted on the side.
Old 10th April 2009, 08:12 AM   #2
chrish is offline chrish  Australia
chrish's Avatar
Maybe post a picture of what you have got, then someone can tell you if it is the selenium rectifier.
Old 10th April 2009, 10:35 AM   #3
Frank Berry's Avatar
If the Fisher is like the old HH Scott amplifiers, the selenium is a bridge rectifier. The size is about correct.
There should be four connections. Two directly from the power transformer, one (the - output) to the electrolytic (possibly through a resistor) and the another (the + output) should be tied to chassis ground.
Hope this helps.
Frank
Old 10th April 2009, 12:12 PM   #4
Send a message via AIM to DigitalJunkie
Does it look like a stack of square metal plates,with a space between each plate,kinda "finned" looking? If so,it's selenium.
Selenium rects on google images
Old 10th April 2009, 01:07 PM   #5
The selenium bridge in the old HH Scott amplifiers is a flat pack ...
no fins. It has two solder terminals on one side and two terminals on the opposite side. It's mounted to the chassis with a small mounting bracket. Fisher may have used a similar bridge.
Frank
Old 10th April 2009, 04:32 PM   #6
Ok here's some pics
Old 10th April 2009, 04:32 PM   #7
Mine looks like the bottom one in this picture
Heres the caption from the picture
Two old selenium rectifiers and on the foreground a modern silicium bridge rectifier
Old 10th April 2009, 05:59 PM   #8
FWIW, I suggest that no prisoners be taken and 4X 100 PIV Schottky diodes be installed. Remember, the negative rail does double duty providing O/P tube bias and heater power. "Zero" switching noise in the bias supply can't hurt and may help. An adjustment to the rail voltage is probably necessary, given the very small forward drop in Schottkys.
Eli D.
Fisher 800c static,crackle skiman762 Tubes / Valves 2 9th April 2009 03:59 PM
Fisher 800c neg bias problem Glowin Plates Tubes / Valves 10 26th September 2008 08:39 AM
fisher 800c intermitant hum slhoward Tubes / Valves 1 28th May 2007 04:16 PM
fisher 800c modifications slhoward Tubes / Valves 1 15th May 2007 11:25 PM
Distortion in Fisher 800C Glowin Plates Tubes / Valves 1 2nd November 2005 06:57 PM
Page generated in 0.09044 seconds (77.40% PHP - 22.60% MySQL) with 11 queries
