Simple PSU question
Simple PSU question
Old 24th April 2003, 01:32 AM   #1
Magnetmaz is offline Magnetmaz  United States
Magnetmaz's Avatar
Send a message via AIM to Magnetmaz
Default Simple PSU question
Lets say i have a bottlhead foreplay preamp, and a bottlehead seduction phono stage.
Lets also say that i want to have the two units use one common power cord, but they will each use their existing power supplies ( stock from the kits )
So essentially, the IEC cable would run to the phono stage, but would be split off before the on/off switch, and run directly to the preamp. They would share a common earth ground in this arrangement, i figure. Think of it as a daisy chaining of a power cord off the phono stage and over to the preamp.
Can anyone say this is a good or bad idea? The reason i am doing it is purely cosmetic ( the seduction has an IEC socket built onto the top plate, the foreplay doesnt. If i can figure this arrangement out, its one less power cord needing to be run. I'm building both units into the same chassis )
I know everyone is going to say "why not just design a power supply that will do both phono and preamp ?" ...but that wasnt my question
any advice at all...
-Maz
Old 24th April 2003, 01:46 AM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default SHARED CORDS.
The result is going to depend on how you implement this, at the very least keep your daisy chain twisted and away from sensitive circuitry.
I don't feel it's a great idea but you may get it to work.
Just my two cents,
Frank
Old 24th April 2003, 02:44 AM   #3
Magnetmaz's Avatar
Well, in this case specifically the power supply circuit is well located ....and the daisy chain part will be short ( like 3-4" ) and kept away from tubes and whatnot.
I'm more curious about spikes, grounding issues and whatnot. Perhaps they both shouldn't run on the same cable, because its two seperate power supplies drawing on the same wire?
Is that nonesense?
-Maz
Old 24th April 2003, 03:02 AM   #4
fdegrove's Avatar
Default FIRST THINGS FIRST.
That would work although I'm not sure why you want to trake chances here.
I'd rather keep powercords as far away as possible from any circuit anyway.
Seems it dawns on you...you may have to tackle each and everyone of them...
Is that nonesense?
No, and I'll refrain from quoting lyrics by ELP...
Frank
Old 24th April 2003, 03:33 AM   #5
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
Maq.....its fine on what you want to do..... use star grounding..... and I would get a small toroid Iron core and wrap the hot and neutral about 4 times through it and then distribute them to their respective power supplies........sheilding the transformers are a good idea also.
Cheers!!The DIRTŪ
Simple PSU questionHide this!Advertise here!
A simple question from a simple man. inteificio Solid State 5 17th October 2005 03:00 PM
Simple Question stoN_Cold Solid State 2 3rd October 2005 10:56 PM
Simple question... Quattor Solid State 7 23rd June 2004 05:41 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
A Simple Question OMNIFEX Multi-Way 3 19th July 2003 08:11 PM
