Transformer in the cathodes ??
Old 10th April 2009, 04:46 PM   #21
Bandersnatch is offline Bandersnatch  United States
hey-Hey!!!,
The screens have a dropping R from B+ and a cap bypass to the cathode node. I tried ref'ing them to ground with various regulators and with signal on the cathodes( and thus a signal-varied g2-cathode voltage) found the results not to my liking.
I found the ratio of g2 to anode current smaller in the 6AC7 v. the 6AU6. The 6AU6 is a very fine small pentode, very reasonable claim to being the 6SN7 of pentodes...linear, useable( and useful ), etc...
cheers,
Douglas
the Tnuctipun will return
Transformer in the cathodes ??Hide this!Advertise here!
Any 9- pin rectifier tubes with separate cathodes? Lingwendil Tubes / Valves 20 20th June 2009 04:57 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Pentodes without cathodes? Hendrixon Tubes / Valves 9 3rd April 2007 01:06 AM
Heaters for cathodes with a large swing lndm Tubes / Valves 1 21st August 2006 03:02 PM
Directly heated cathodes, but why? Hesky Tubes / Valves 12 8th June 2004 12:18 AM
